NRK1 and NRK2
fearny23
Hi all,
I noticed that NRK1 and NRK2 are no longer scrambled and are free to view. Anyone know if this is going to last at all?
bremze
Dreambox 500 with Hydra image
fearny23 said:
Hi all,
Don't know about the others but I have a problem getting these 2 channels. I try manual search entering all data provided by lyngsat.com but it doesn't work. May be I have too small antenna (700mm) or am I in the wrong place (Latvia)???
fearny23
You live in Latvia?
I went there last year to the Eurovision. Had a great time. Anyway, erm, not too sure but if you have a big enough dish then I don't see why you shouldn't be able to get NRK1 and NRK2.
bremze
bremze said:
Yes, but I'm trying to get them via Sirius. And there is some kind of problem. Later I'll try to enter all data again. Let's see if the problem is in my hands or somewhere else...
Don't think they're on Sirius. What frequencies are you looking at?
Well thats your problem. NRK arent on Sirius! Fta on Thor 3 at 1W.
Hamo
Freesat Humax Fox Sat
Hi, my wife's Norwegian, do you know if I can receive NRK1 via satellite in the UK?
yes but you might need a biggish dish depending where you are in the UK.
