- Jan 7, 2009
- Age
- 58
- Some SAT-related hardware.
- N-E from Riga
Alex! Yes, the new holder goes directly to the original CM feedarms. After installed, it gives possibility to position LNB exactly how the original (plastic) holder does. But, in addition, it is possible to change the position of the LNB up/down, change the aiming point, and, of course, change the skew.does your holder support original ChM 1.2 arms
More or less yes, correct.location of lnb for original arms and plastic holder for ChM 1.0, 1.2, 1.8 Is correct, but there Is only Issue with lnb pointing to center of dish Instead of slightly down
