This plugin shows epg from web sources. Specially, it shows epg for all the channels in the source directly (not only the channels in bouquets).
It is a Beta version - please test.
For now the web sources are from Rytec and Ambrosa. Many thanks to those behind these sources.
There are two plugins in the ipk. EPGUpdate (in the Plugins or Extensions) and ViewEPG (in Extensions and INFO - long press). EPGUpdate configures the source import and has a frontend similar to the plugin EPGImport.
The autostart is at bootup and enigma2 start. So if you are doing Restart enigma2 for other reasons - please "Disable" autostart.
Some images may need gzip.py (in folder /usr/lib/python-2.5) and zlib.so (in folder /usr/lib/python-2.5/lib-dynload chmod 755). These are attached.
The epg updating takes some minutes - so please be patient. It can be checked with ViewEPG.
Regards, pcd.
Regards, pcd.
