plz help regarding Dish india TV in China
M
muddu
KU-band DTH , Dish TV INDIA
china
Hi everybody plz help me , i have 90 cm Dish India Tv provided Dish & Ikoan -i260mco Setup box withUniversal Single LNB Modul FS8, as i have seen the foot print of NSS 6 brid in china at 95E, but still i cant get the channel & i cant see anything connecting or any respons from sattelite, kindly guid me to set up it , i hope this can be use in china
i will be thankful to u
afancier
afancier
Zenaga STB CD1002S, Three solid Ku band Dish. 60Cm,70cm,90cm getting Nss6 95E, Yamal201 90E, ABS1 75E, EuroBird2 26E at 26E. Disec SWITCH
Amritsar
first try to get some ku band of china....... like of asiasat........ so u get sure that u can get it..........
Skybox F3
Which bit of China do you live in - its a big place!
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
PCI SAT CARD TWINHAN NSS6, PAS7/10, ASIASAT3S, INSAT,INETEL SAT, EUROSTAR, DremBox, & Multi LNB'S
INDIA
Are you sure muddu...! We are not sure....!
M
muddu
china
i stay in south china city of Guangzhou itz 170Km from Hongkong
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
Soo r u sure that you can get it, If yes then find your LAT&LONG, Then we will provide you AZ&EL, Soo that with that info you can tune your dish. But i am not sure with 90cm dish of yours, Try to use bigger one, Lets see your LUCK.
M
muddu
china
i dont know wat is LAT&LONG ??? plz explian , and i have seen many people get here Zee & som indian chennel which is free to view , but im not sure from which they r gettting this ,
afancier
afancier
Amritsar
tell me one thing.......
did u ever go to ur roof and try to get some bird.......
i told to u that try ku band of asiasat............ or telstar 76.5E........... it's for chinna and u must get it............
but i guess u wants to discuss only...........
go and do it man............
what u waiting for............
or call me...........
but don't waste time on one thing.....
it's enough now........
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
Find you place and tell me here, Get it Lat & Log from here and tell us...!
h**p://worldatlas.com/webimage/countrys/asia/cn.htm
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
He is dam sure that he can get it, I don't know how...? We said it earlier that cant able to receive it he said i can.
Skybox F3
Our chinese friend doesnt seem to appreciate sometimes you cant get what you want no matter what you want and wish for.
member91040
member91040
DISH TV,DIRECT DD+,
TATA SKY,HATHWAY,
NOKIA 9660S,
INDIA
Soo how should we handle this kind of things...! We said try it, Until you would be sure from your heart.
Skybox F3
Folks should always try things to see if they can get something - theres always the chance of freak reception conditions.
Most of the time we have to give educated guesswork advice - no-one is an expert in all aspects of satellite reception, we can only give advice and information based on the published downlink maps. Just occasionally someone proves us wrong :D
J
jc001
2m satellite dish
hk
muddu, I also live in china. can't get Nss6 signal for DISH TV in china. only Asiasat 3S. if you have questions, please contact me. my email is EMAIL REMOVED my mobile is REMOVED. jack
M
muddu
china
i gave up trying for Dish Tv as it not possible to get Dish Tv in China , as it beam just in india im thanful to Satellites.co.uk & all itz member who guided me , so forget about it , now im trying for Tata Sky there is littile hope that can get TATA Sky , if u want to contact me check my profile & send me email , i stay in Guanzghou
RealInfo
RealInfo
DM 120 cm dish
Punjab
no tata
no dishtv
with 90 cm dish
try to get 150 cm dish
M
muddu
china
im using 180cm solid dish , i tried using tata sky Tp & freequency in chinese made setup box , but i dint get it , but i can see alll other chennal from insat 83E , im waiting for Tata sky setup box , let check
srei
srei
coship receiver 2000,Dreambox 500;2 ku3cband dishes of 2,4,6&8feet,amd 64 pc with 1GB ram usb tv tuner card
north west india
You better get reception of Free to Air Channels from Insat 2 e@83,Panamsat@68.5,Asiasat@105. Forget the so called DTH,and
return to India if you cannot resist the temptation.
N
nagaya
Technosat FTA777 + DISTTV LNBF 0.5dB Noise + 60cm Dish + Core2Duo PC + Philips TV card + Philips CRT 19"
Sri Lanka
But u should get signals on FTA reciver if u use right size dish..
even me get DISHTV TPs with $ mark on mu FTA reciver....
I'm in SL and so i get 98% Signal on 12638Mhz TP with my 60cm dish...:-bubbly:-bubbly
for other TPs itz around 80%
