plz help regarding Dish india TV in China
M
muddu
KU-band DTH , Dish TV INDIA
china
nagaya said:
But u should get signals on FTA reciver if u use right size dish..
even me get DISHTV TPs with $ mark on mu FTA reciver....
I'm in SL and so i get 98% Signal on 12638Mhz TP with my 60cm dish...:-bubbly:-bubbly
for other TPs itz around 80%
I tried tata sky also , im not getting any signal from tata sky, but still i can see all other chennal from insat83E , plz advice if any trics that can work for me to wtach tata sky or Dish tv chennal
thankz u
Skybox F3
thankz u
Tata Sky is using an Indian spotbeam, and will not be possible in China.
If you want to watch the Indian channels you need to move to India!
M
muddu
china
if Tata Sky is using an only Indian spotbeam then how can get chennal singnal in Dammam KSA ? i myself have seen it there , so it might be possiblites to recive signal in china too ?
Skybox F3
1) There is some overspill if you use a big enough dish - People in the UK can receive Nilesat if they use a massive dish although its not officially available in north western Europe.
2) Saudi Arabia is failry close to India geographically - in a previous post you said you were reasonably close toHong Kong which is a long way from India.
You could probably pick it up if you put something like a 20 foot diameter dish up, but is it worth the time and money to find out??
Moradabad
Moradabad
SAT SPECIALIST INDIA
One 12 Feet Heavy Antenna, one 10 Feet Double Rib Antenna
Dreambox Dm500S, DM 7025. HD Receiver,Envision,
Eurostar receiver, 4 Dual LNBS, 5 PFA Lnbs
india
HOTBIRD, Eurobird 9 & Eutelsat w3@7E signals are for Europe and does not cover INDIA.Still we are able to get all the birds till mid & South INDIA. Because we use a perferct or very good big 3 to 4 meter dish antenna.
M
muddu
china
hi all spl realjack , im back with new issue here , i have seen vedeocon D2H which use ST-1 satellite have its beam all over china see the footprint below link
-http://v2.eprognostic.com/powered/site/services.php?id=39 ,
kindly check with ur knowledge that this can work in china ??? plz help me to find it out so i buy vedeocon setup box m kindly advice
Skybox F3
From those footprints you will have a very good chance with anything transmitting on the eastern Asiatic beam, but forget anything on the K2 Indian spotbeam :D
Moradabad
Moradabad
india
Hey MADDU we in india receive both the beams of ST1 k1 & k2 so I think same way it should also work for you.
And above all I tested this in all over india it works fine. Hence you can also hook a 120 CM offset antenna and try for this signal.
We receive both signals in 60 CM dish.
