Problems in Spain
Brian Philpott
Broken Allsat Vbox driving 1.8 Laminas dish
Spain
Cannot correctly receive signals from Astra 2g in Formentera del Segura , Alicante, Spain
Need advice to correct.
UK beam or Europe beam as well? Do you receive anything from 28.2/28.5 east?
Brian Philpott
Spain
UK Beam. I can receive most of the uk beams, ie. bbc ch4 etc, but for some reason no ch5
Which transponder/channels did you use to peak the dish? Do you receive any channels from the 2G UK beam on this list or is it just the Channel 5 transponder that you have trouble with?
Brian Philpott
Spain
I used 10818V to set the dish up. I can get Smithsonian HD, Magic UK etc. but no ch5
@Guinness 1964
You seem to have a "broken V-box" - thus, maybe, your dish isn't now aligned correctly enough to now receive Astra 2G???
Brian Philpott
Spain
@Guinness 1964
Don´t need to ask who told you that! Ask her for my email!
@Guinness 1964
AH, you are online! - so, now, just what did you mean by saying your V-box is "broken"??
Edited: it might also help if you could tell us which receiver you are using.
Brian Philpott
Spain
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
it could be a faulty LNB or a local 4G interference
10818V is on Astra 2E 28.5 east... 2G is 28.2 east - not an insignificant difference. Peaking the dish on a 2G transponder will give you a better chance of receiving Channel 5 - at the expense of 2E signal levels.
