Satalitics
- Dec 9, 2017
- Age
- 61
- 6ft pf dish
- Kenya
Can the ones used on Windows/Door security sensors work?Hi -
I,v struggled a bit to find these in the past ... a search of e-bay (satellite actuator reed switch) brought up an Australian supplier ... cheap but a bit costly on the postage ... I know satellite superstore up in the N.E. uk have them - 3 types listed on their website .. but at a price ... might work out more than the Australian one ...
regards ..
Found these which are almost Same size as the one in the pictureHi-
I,v never tried one ... but in theory i think it should do ... the problem is they are quite large and it may be difficult to get it positioned near enough to the Magnet wheel for it to work properly ?
I got mine from here - Actuator Replacement Reed SwitchI need a reed switch, do you know the specs of the reed switch to order it?
It's just an on-off switch. ~5VDC pulsing from your receiver.Thanks but im not in UK... Do you know the specs of that reed? I have here lots of stores that sells that reedswitches but without the plastic cover. some are 0,5watts some are 50watts with different voltages also, but I dont know what is the most suitable to buy.
