Nickle
- Mar 21, 2006
- Age
- 65
- Triple Dragon
- UK
I only had my TD for about a month. Both on the previous image (March) and the current TDMAN_10a image I have a problem where the TD stops responding to the remote control after about half a dozen keypresses. All th ebuttons stop working including on/off.
Makes it hard for moving down favourites etc. the controls on the front of the TD itself work OK and quite often pressing exit button on the front then makes the remote work for a while again.
When it has locked up, the red light flashes on the TD when a button is pressed on the remote but nothing happens.
Any ideas or is it a hardware problem.
