EDW
- Nov 18, 2003
Thanks to Zildan and RSP team, load with KCC as usual. Go to x must be on for rotor to work. Long and lat settings may get corrupted and need redoing, so check them if problems.
First boot set up rotor, then reboot check network (buggy) download emus, cannot mount record partition.
RSP beta01 TDT1967 Neutrino ufs910
Usb image
RSP Neutrino panel V1 (Menu > Script)
Ecm Icons
Enf70 settings
Emu Download: press Ok and wait ..... and all emu is downloaded, repeat Ok and download all emuconfig
Emu Select: switch emu cyclical (next Ok next Emu)
Emu Start / restart: restart emu or start selected emu (by Emu Select)
Emu List: list installed emu
REBOOT: restart Kathy
For E2 RC k_ey style:
Download k_eys.zip, unzip, copy in /var/tuxbox/config or other folder and go to menu Load K_eis from.
Usb image
Ecm Icons
Enf70 settings
