Russia
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Am off next week and looking for advice on any iptv or videostreaming of freeview channels.
Cant find anything robust?
Had a look at _www.europa-network.com in Spain but they say their stb cannot be used outside Spain.
Anyone reccommend anyone?
Cheers
What broadband system are you likely to have once you get there ?
And which part of Russia ?
satelliteman
Sling media would be an option depending on b/band connection.
andyw37
SkysNotTheLimit
Tring 90cm & Viasat
Moscow
Thanks both for reply.
Channel Hopper I will be in Moscow and told there is a reliable 2meg broadband connection.
I hear someone else is using slingbox but not much cop?
This is a real lazy question does anyone know what english channels / footie would be availiable. Job is a big change in direction for me so the sat tools will become my second skill!!
Thanks in advance.
If you had a slingbox you would get all the channels you are subscribing to. A 2 meg incoming stream would be plenty.
It might be worth reading up on it.
