- Jan 1, 2000
- Age
- 81
- The Flatlands of East Anglia
Mickha said:Finally found a couple of hours, of dry weather, to dismantle the dish and drill the two holes. It has improved performance, as now the dish is properly supported, I haven't had time to fine tune the arc, using the incredibly awkward adjuster mechanism, but by just adding the 2 extra bolts, for support, I have improved signal quality, on all satellites, and got it tracking from 39E to 1W, all I've been able to try so far. It has also cut down the noise, I could hear the dish slightly moving, due to insufficient support, when the motor moved previously.
The clouds rolled over just as I was re-assembling the dish, so good timing.
I'll eventually get round to fine tuning but at least it's working correctly now.
I certainly found the declination adjustment awkward Mickha. I had to loosen all bolts on the two extension brackets and physically push the dish up from the bottom of the Gibby, tighten all bolts except the ones that join the top declination plate, to allow 'down' adjustment of the declination.
