Smart card tivusat
Pepeyeb
Eutelsat 5 W B con antena de 1m.
Receptor de satélite Octagon SF 8008
Toledo (España)
Good morning
Does anyone know any procedure to watch tivusat channels (I have the official smatcard) with my Edision OS receiver?
Or is it that I need another receiver for this tivusat platform?
Thank you
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
Good morning
Thank you
hi ,
is your card activated thru tivusat site??
Pepeyeb
Toledo (España)
Hello
Yes, the card is activated on the tivusat site.
I use it in a Fuba ODE 712 HD receiver, tivusat certified receiver.
The Edidion OS mio receiver does not recognize the smart card.
pipino
Back from the dead
Hi i think you should program your box with Mcas (emu) firmware that should work in the case of Edision picollo box etc ...your box is based Enigma2 so a correct oscam with Tivusat RSA key should do the job
cheers
Pepeyeb
Toledo (España)
Thanks for the reply.
These issues are complicated for me.
Pepeyeb
Toledo (España)
Good Morning
I have installed the 2 files from the link and the Oscam works perfectly to see tivusat with the smart card.
It may be useful to someone.
Pepeyeb
Toledo (España)
