Tbs tuner and crazyscan - probably not a pc card issue
Can anyone send me a link to the most recent Crazyscan download ?
I had a go at installing one earlier on the Win7 PC (32 bit with a TBS8920 card) , but I get the attached message.
The original TBS software and channel recording works fine btw, if a little slow which is why I'm thinking it may20200415_192723.jpg be a driver compatibility issue.
Thanks in advance
Ref QTCDore4.dll: check if that is actually in C:\Windows/System32 - in which case, it's not being recognized by Win 7.
If it is there then try opening a Command prompt and using (IIRC) one of the "regserv" commands (can't remember which one ATM!) to "register" that dll - after that then maybe the error message won't crop up.
OTOH, if the dll isn't in System32 then try to google and download that, put it in System32, "register" it as above and then try the original process again
Already done that, though what do you mean by registering a dll ?
Oh well - win some, lose some :lol:
Maybe check with crazycat to see if he can send you the dll?
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Doesn't QTCDore4.dll just sit in the crazyscan folder? Is it not one of the 'dependency' files that have to be downloaded as well as the main files and added to the crazyscan folder? Been a while since I used crazyscan, but that's how I remember getting it to work.
The original TBS software and channel recording works fine btw, if a little slow which is why I'm thinking it may be a driver compatibility issue.
Thanks in advance
The ReqLibs files need to be located in the Crazy Scan root folder. It is not just a download of the Crazy Scan rar file, it also needs the ReqLibs rar file unpacking into the root folder
AFAIK and in short, sometimes a dll is downloaded to System32 but not actually "registered" in the WIN Registry - and thus it is not recognized by the App loading process. Therefore you then have to use the regserve process (probably with switches) to get it "loaded" into the Registry - google "register a dll" and that should tell you what to do.
OTOH, given what @Dave5118 just said about where that dll should be located, then, having opened the Command prompt, you might have to navigate to that folder in order to then successfully run the regserve command.
PS: I now "bow" to moonbase's far superior knowledge of this subject:-clap
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
I've never had to run the regserve command on crazyscan or associate files as far as I can remember though.
Thanks for the answers, the original question was in part the issues, but I may not have the most recent, or even official Crazyscan file here.
It might not even be for a Microsoft operating system. So where might I find the correct download ?
...PS: I now "bow" to moonbase's far superior knowledge of this subject:-clap
I had the same problem getting it to work a few years ago when I first installed it. There were no clear instructions at the time but I think there was a topic on this forum about it that helped me resolve the issue?
I pasted a link above to the sourceforge.net site where you can get the Crazy Scan download and the ReqLibs download.
Ah, OK. thank you, I will return to the dedicated PC tomorrow once downloaded.
...to which must also be added StreamReader.dll & .ini.
Here's what the Crazyscan folder looks like:
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
MSVC 2008 32-bit runtime libraries must be installed + QT 4.8.x 32 DLL in app dir. But TBS8920 not supported :)
CrazyCat
crazycat69.narod.ru
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
Is anyone else having a similar issue with the latest StreamReader v.1.2.4.26?
Blindscanning TPs in Crazyscan shows zero dB in found frequency/SRs :confused
The Monitor shows the correct dBs for each locked TP.
Reverting to my last StreamReader gives the correct dBs.
Seems to be ok here Llew, loaded the new files up this morning.
A quick scan on 3.1East C-band - TBS 6983 card.
CS Scan.jpgTBS 6983 card.
View attachment 143241TBS 6983 card.
Very odd.
OK, I'll have a root around the files.
