Technomate TM7102 HD-T2 Super problem
daro2096
No setup at present
Consett, Durham
When recording a programme through the timer, when the timed recording ends the receiver goes into standby. This is annoying as this receiver takes about 3 minutes to get to PVR ready status from standby. Is there any way to program this receiver so it doesn't go into standby mode at the end of a timed or epg recording?
thehumangoing
dm800se clone w/320gb hdd (DreamboxUK image) + skybox f3 + old dm500s
zone 2 on 28.2e
Ireland
have you tried looking in your PVR settings, i know on my dm800se you can choose what it does after the recording.
daro2096
No setup at present
Consett, Durham
How do I do that?
Archived-1
Persona non grata
uk
I would take a look in system settings then time settings and make sure the last 4 settings are turned to off :-).
daro2096
No setup at present
Consett, Durham
They already all turned to off but receiver still goes into standby mode at the end of a timed recording.
Archived-1
Persona non grata
uk
I cant help then sorry, I do hope you find a solution :-)
twosats
Technomate TM7102HD.
Astra 19E & Atlantic Bird 5W
Oxford & Durham
Here's a similar problem with the same machine / PVR combination (Technomate TM7102 HD-T2):
The PVR is recording a new programme which I have set to record from the EPG.
While this is going on I am watching an older programme already on the PVR which I had recorded earlier.
When the new recording gets to its end, the receiver switches off / goes into standby without warning
and I have to restart it to get back to the programme I was watching.
Any ideas how to stop this happening?
I have looked through all the menu settings and the manual and I can see nothing about this issue.
