TomTom Go 500 Map problem.
good2talk
good2talk
Nothing at the moment until I find a receiver.
yookay
Hi M8s,
I have just bought a TomTom Go 500 and found some of the streets are missing in the map. Is it old map or something else?
I am using the original software that came with it in SD card.
What is the solution? Please help!:-cry1
Your help will be much appreciated.
T24
T24
Info Exec
I have bought a Garmin Nuvi 300,same here..some of the streets are missing,we have to wait for updaing ?
P
pgh13
Midlands UK
I was on the A1 where it crosses the M62 last week.....it the TomTom knew where it was but didn't know that the road had moved and so kept shouting "after 80 yds turn left"
good2talk
good2talk
yookay
How to update with latest map & speed camera database?
T24
T24
Info Exec
There is a loader program to load the speed cameras into your TOM TOM,for example I am using POIs loader to load my Garmin.
I
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
same here the a1 really sends the tom tom crazy whats the latest maps available
D
Digital2
Dreambox 500s,Dreambox 800HD PVR,Max 1000,Vivax 505, Starsat 200CI. Desktop with WinXP, Laptop with Vista & Netbook with Win7. External HD/Media Recorder.Hotbird,Nilesat,Asiasat3S & Intelsat.
Middle East (Currently!)
I have a NUVI 310 and POI loader but am NOT sure what POI to load; any suggestions plz? Another query is whether I can put the maps from my NUVI 310(GCC MAP) and give it to someone who can put it on SD card and use it on his device (If it can be done, I'll upload my maps here so our members could use it!)
Regards.
K
kitschcamp
TiVo & Sky/Astra 2D on a 1.8m Andrews dish. Canal Digital on 80cm fixed dish. DM800HD and DM500 on both dishes.
Eslöv, Skåne, Sweden
good2talk said:
Hi M8s,
The 500 is about 3 years old, so unless it was upgraded the maps will be three years old - I've got exactly the same model which I bought way back!
You can upgrade the maps at TomTom's website for a fee. My current maps are V710.1571
