Trying to make CCCam 2.2.1 work for Enigma2 Nemesis Blue Panel!!?!
lord02
DreamBox 7020HD
Nemesis Blue Panel, v2.6 SVN 107R5
Enigma2: 2012-03-27-3.2
Image: Release SVN (107r5), 29-03-2012
Iceland
Hi there,
Can someone please help me out ...
I'm trying to get CCCam 2.2.1 ( not 2.3.0! ) working on my new DreamBox 7020HD.
I've already installed it through TSPanel addon and it installed just fine.
But in the Nemesis Blue Panel, when I press the blue button and try to change the SoftCam,
it doesn't find the CCCam 2.2.1 ( although it was installed TSPanelTsBin ) in the list ( only DCCam or something like that )
Now I've also tried manually installing 2.3.0 and then it appeared in the list, but I specifically need to use
CCCam 2.2.1 ( instead of the latest version! ).
I've already copy / pasted a C line into:
/etc/CCcam.cfg ( it just has ONE line, the C line )
Can somebody please answer me the following questions:
01 - where can I find the CCCam 2.2.1 for this exact image, I need the *manual* installation ( for the blue button to find it )
e.g. the .tbz2 or .ipk file, so I can put it in \tmp\ and do a manual installation:
I need CCCam 2.2.1 for this image I'm using:
02 - Do I need to rescan my channels after installing CCCAm 2.2.1 ?!?!?
03 - Why doesn't the CCCam 2.2.1 show up in the "Blue button" list, after I've installed it through TSPanel
In any case, I should be able to just manually install it ...
Welcome to the Forum.
I have edited your Post slightly as the Forum does not permit discussion of matters clearly related to Pay Servers.
Nevertheless, the ins and outs of setting up boxes with plug-ins etc. is fine, so hopefully someone can assist you without testing our Forum Rules too much.
A nonymous
If its Nemesis you are using you need to find out the extra.url and ftp it to the box. You will then be able to install the emus directly off the nemesis server.
If you install off the tspanel you have to make sure its the right emu for the image, as each installer is different for each image, i.e camscripts, locations of files etc etc.
if you Google nemesis extra.url you should find the info you require.
Nano
lord02
DreamBox 7020HD
Iceland
Hi Nano,
Where do I FTP this extra.url into the box **and how** to I load it up into the "Blue" menu to be loaded as a current CAM** ? Can you please give me more detail on this ... I've already done this for .tbz2 and .ipk files ... but they're currently not the corect version for my image apparantly :-(
Where can I find the CCCam 2.2.1 for my exact image?
I think the TsPanel already "knows" which Nemesis image I'm using ? But ok ...
Do I need to rescan the station list after installing this extra.url and enabling CCCam 2.2.1 ?
lord02
DreamBox 7020HD
Iceland
I've googled it and they're talking about FTP'ing this file under:
File extra.url be placed in / etc
And then what ... where do I DOWNLOAD the CCCam 2.2.1 for my nemesis enigma2 from now on ?
- Is it possible from the Blue Menu -> Addons -> XXXXX ?? I think they've REMOVED CCCam from the Nemesis Blue Panel because of some "licensing issues"
---> I think I have to do a MANUAL installation, but then I need the correct
.tbz2 or .ipk files ?
lord02
DreamBox 7020HD
Iceland
I was able to get Cccam 2.3.0 up and running ...........
BUT I was wondering if anybody has experienced the same stuff I'm going through with Cccam when watching Locked channels ?!
I'm using Enigma2, Nemesis Blue Panel, v2.6 SVN 107R5 ... and Cccam 2.3.0 ( have also tried Cccam 2.2.1 ) and this is the problem:
I *am* able to unlock the channels, BUT if I'm switching between channels ( not fast, and not that often ) all the channels become LOCKED again ( i.e. just black ),
and the only way for me to get them unlocked again is to RESTART the Dreambox itself ( it's not enough to restart Cccam or Enigma2 ) !
Has anybody experienced this weird behaviour ??? I'm only subscribiting to a single sharer(trial for 24 hours), which is supposed to be one of the best on the market
(only one C-line) and everything works just fine if I don't flip the channels !!!?
I've also tried changing to the Free-Over-The-Air channels when the payed channels get locked, and those channels(the free ones) are still OK !
Please help me out here guys, thanx in advance
Setup:
DreamBox HD7020
Enigma2,
Cccam 2.3.0 ( with only one C-line in the config )
You've been warned about discussing card sharing. Re-read the rules on this subject - Any further questions involving CS, and you will be banned from the forum.
