uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Is there any epg on the Freeview channels on 27.5W ?
If not, what is shown on the red button channel ?
You can import EPG into enigma2 with the help of plugin EPGImport. So I have a Tv schedule for 5-7 days ahead with detail description...
superpascu2
ATLAS HD100 - ASTRA 19,2 + HOTBIRD 13 + 28,2 1.2m famaval
Alicante
Is it possible to open 11495V in 27,5W?
I mean, with biss keys. How long change them and how simple is to get new ones?
18 channels in just one transponder (5 of them in HD), how about the image quality?
nwaggy
1200 dish twin lnb full sky plus 907 to keep her happy
nerja costa del sol spain
Its quite simple you have what you see you don't get any more the picture in spain is perfect its a good quality broadcast and greatly appreciated
superpascu2
Alicante
I understand what you mean but could you tell how long the biss keys last? In order to have an idea how often I have to change them.
VodzigorLans
Setup is down atm
RU, Saint Petersburg
Last time it was changes 2 or 3 years ago... but before that it was changed very often so there is no guarantee.
HD channels video quality is fine but SD channels quality is bad, audio is AAC ~130 kbps not AC3 like 28.2e.
Eusebius Punz
Oberndorf, Lower Austria
Wavefrontier 30" W - 28,2" E
Oberndorf
You can see 11 sd tv-channels, 6 hd-tv channels and 11 radio-channels. The rest is not watchable.
Take a look at These sites. Intelsat 27.5°W 907 Freeview BBC pack - BBC One HD, BBC Two, BBC Three, BBC Four, BBC HD, ITV 1 HD, Channel 4 HD - PiXieSAT
BBC-SATBACK – Astra 2 Sat
Intelsat 907 at 27.5°W - LyngSat
mesicek7
vu+
Slovenia
I apologize in advance if im not writing in the correct thread.
I recently got a 2nd dish from my uncle and im thinking of using it for the 27.5W BBC channels. After looking at the recent posts they still work right? My location is central europe, the dish size is around 80-90cm, receiver is a Vu+Solo. Is it possible for me to receive these channels?
thanks
90cm is marginal for that footprint in Slovenia You will probably be ok in fine weather but not have much rain fade allowance.
Eusebius Punz
Oberndorf
If you are inside the 44,6 db beam like mine you Need 90 cm. I get this beam with a Wavefrontier T 90 on Pos. 8 degrees, means i get about 90 - 95 cm dish size. In good weather all is okay. I get C/N 8, Signal strenght 66 % writes the Receiver.
But with FEC 9/10 the Signal goes down 20 percent at bad weather and i get no Signal. I would say: marginal with the 44,6 Spot: 1 meter antenna, Outside 1,2 meter.
mesicek7
vu+
Slovenia
Would a good LNB - something like the Inverto Black ultra help in any way?
@Euesebius Punz
U mean this?
Satbeams - World Of Satellites at your fingertips
I'm not even in the field of the beams since my location is close to Ljubljana
So thats a no go for me then :(
Ljubljana is a beautiful city - fab views from up at the castle :)
The signal doesnt end suddenly at the end of the map - it just weakens gradually the further out you go
Eusebius Punz
Oberndorf
Of Course you Need a good LNB. I think in your Region you Need a 1,5 m antenna. With no guarantee. You know the Troubles with BBC-Satback? You have the right Receiver?
humaxboy1
Octagon SF 4008
Slovenia
Information from the first hand..In Slovenia 100-110 cm is enough. With 120 cm I have almost 11.5 db.
antrabe
dreambox7080 dm900 viark droi
spain
works with last oe2.5 for dm7080?
RESCO
Rather then highjack the main thread on this subject I just need to ask a simple question about this service
If you put Phantom Patch on Technomate reciever are the BISS keys loaded or do I still need to enter them manually
Cheers
Mod.Note The sentiment is appreciated, but as your query is directly relevant we'd prefer Topics not to proliferate
Nagusia
Gibertini 0p150 with single Inverto Black Ultra plugged into Humax FOXSAT HDR | Portable 80 cm dish with IBU plugged into TechniSat SkyStar USB HD DVB-S2 receiver/W7 64 Media Center / ProgDVB setup.
20 km south of San Sebastian N Spain
Yes, you need to load them manually.
Adam792
Cheltenham
I think it got asked at some point on here what regional news is carried on BBC ONE (England SD) and ITV HD on this satellite feed.
I've investigated that this lunchtime -
BBC ONE is the actual network feed with no regional opt-out - when the regional BBC One versions would have their regional news, this version carries on showing the BBC News channel, until the national weather cuts in (which was mid-sentence during the signed news this afternoon at 1:30ish).
ITV HD is London. I think it used to be Central (according to KingOfSat anyway) but it was definitely carrying London at 1:55 today.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
27.5w working fine on Tm5402 and 60cm triax in hull.
