Just Sharing This Gtmedia or free sat v7 hd satellite tv receiver
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
skomedal
This and that
thule
First impressions its a great little box very pleased with it, will do a few tests and report back
Good luck with testing:)
If possible can you test the box tuner for fringe satellite reception sensitivity from your UK location?
Regards
blademedia
Sky
what satellite are you using it on?
Various satellites John, its main use will be blind scanning for me, blind scan is quick and that's what I wanted, picture quality is good, I need to do more tests,
Regards
Yes will do skomedal its one test that's important to me
I might send it back, as well as no red button, it doesn't decode 4K :-lol
Like expecting a pearl for the price of a peddle (or along those lines!):-lol
Pipedream
Sheffield
I don't find the blind scan very good, but for watching football it is excellent. Picture quality is very good.
Pipedream
Sheffield
When I scan 28.2 east I only picked up half of the free view channels. That can only be down to the blind scan or the USAL being no good. On the same dish a 1 mt Gibby I can receive 57 east to 45 west so I can only assume its the blind scan
blademedia
Sky
Thanks for the information, what software do you have installed and what lnb setting are you using please, appears to be working fine here, but I haven't scanned 28E yet
Running fine with me also. What SW version are you using Blade?
blademedia
Sky
Probably using wrong lnb setting ?, I couldn't find my usb stick so just what it came with V2.24.100.404
blademedia
Sky
Regards
Hi skomedal,
Testing on a weak transponder at 4W two separate feeds from the same LNB, the cheap unit is slightly more sensitive than the TBS 5925, the TBS card was losing signal completely at times the cheap unit was keeping a broken picture.
blademedia
Sky
Can you set scan ranges or is it a full sat scan. I have only managed to do a full sat scan
No you cant set scan ranges, I wouldn't bother with full scan, use blind scan, you can edit transponder's for a manual scan
I've ordered a V8S non-combo box because it has sat RF loop-through and I don't need terrestrial/cable - think I missed the delivery today because we were out shopping, so off to the PO Sorting Office tomorrow morning.
Trip to the PO turned out to be for something else, and so still waiting for the V8S - even though it was picked up from the supplier early on Wed morning for RM "48hr delivery" (which means that it would have normally been here by 07.30 this morning)!
Did not arrive here today either - looks like RM have simply "lost" it !
Ghostleader
Glasgow,ish!
Bloody hell mate, what you going to do now?
Having a "conversation" (shall we call it that out of "politeness?) with the supplier ("cartzilla" on ebay UK) who is now promising that I will get it on Monday - but I have already told them that I am having "difficulty believing them" because of the 4 missed (2x RM postal, & 2x RM packet/parcel) delivery slots since early yesterday morning!
Ghostleader
Glasgow,ish!
Oh dear me, well let's hope this gets resolved soon mate.
blademedia
Sky
Final test, auto roll, it works well out of the box, mentioned before google for this if interested, great little box worth every penny, will be ordering three more
EDIT - Pic removed A/S
