Help Required CM 2.4 m dimensions
Trust
Nijmegen Netherlands
I have to make a lnb changer for a CM 2.4 m offset dish .
Can someone tell me the exact size of the dish , hight , wide and dept ?
Also like to that both half parts have the same dimensions .
Youu have asked this before, from memory I've posted the answers, or at least a link to a series 243 reflector design.
Hang on a mo.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Wim! Red digits on the collage are for 2.4m CM. Have fun with changer.
Trust
Ok Guys , thanks , only the dept size fails , who knows it ?
Have to build it for a Romanian fellow with a beatyfull dish and motormount .
archive10
An absolute beauty.
The mount is an Apexsat H2H mount for large dishes.
Constant movement vs clicks across the arc from eat to west.
For 2.4 or even slightly bigger (could probably do a 3 meter).
Have one on the roof at work with a 2.4m CM...
Channel Master 2.4m galore
RimaNTSS
N-E from Riga
Updated my collage with depth. Measurements should be taken at the very middle of the dish.
Edited: I have changed the picture for the most updated one as of 16th August 2021.
