Edision Primo: E2 Channel Lists
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD Qaud 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
Not sure if it's been mentioned in this thread or not. Quite a long thread to read through. Do you guys know that you can send Enigma 2 channels lists to this device using Dreamboxedit?
Not actually tried that, but one member on here said that it corrupts, but that was the OctagonSX88
World-of-Satellite
VU+ Ultimo 4K
GiGaBlue UHD UE 4K
VU+ Zero 4K
I've give it try later, got some instructions from Edision.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
This does work, I've done it with Dreambox Edit and Also E-Channelizer.
Username: root
No password.
The paths you want are these:
Satellites, cable, terrestrial (xml): /home/gx/local/enigma_db/
Service and bouquets (tv/radio): /home/gx/local/enigma_db/
Make sure "Auto Reload Settings Enigma2" is enabled. The software will throw an error up but just ignore that, without it sending that command the box will not apply the changes.
