Primo IP S2 General Chat
Multistream T2MI Support Ku Band
Hellas Sat-3 @ 39°E Bulgarian FTA channels
Astra 4A @ 5°E Ukranian FTA channels
Eutelsat 5 West Atlantic @ 5°W Italian & French FTA channels
Eutelsat 12 West Atlantic @12.5°W Italian FTA channels
I have also added some multi streams from 30 west FlySat Hispasat 30W-4/30W-5 @ 30° West
11342 V 34285 DVB-S2/8PSK MPEG-2 Telespazio 2 streams
11496 H 7884 DVB-S2/8PSK MPEG-2 / MPEG-4 ATV Telecom Bouquet
How to add active Multi-Stream TV to your Edision Primo IP S2
The Blind-Scan works fine for finding normal SD & HD transponders,
The Primo IP S2 does not actually find Multi-Stream Transponders with the Blind Scan,
You can activate the current transponders for Multi-Stream that are in your database by making your 1st scan on a satellite with Multi-Stream selected,
How to do it:-
Go to instalations on the satellite that you want to scan then TP list & delete all dead transponders,
Now move to Antenna settings & press OK on the satellite you want to search,
Press the red search button,
Now select as follows in the sub-menu:-
Mode = Auto
Multi-Stream = On
FTA only = On
TV/Radio = TV
NIT Search = Off
Search = Press OK
After this just use the normal Blind Scan without activating the Multi-Stream in the scan to update your database,
If a new Multi Stream starts or a current one is missing from your database then add the data manually from here FlySat Sat List then follow the instructions in the sub-menu above.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Got mine coming tomorrow, can't wait :D
40E in C band can be had on a small dish (I daresay 1m might be enough), which has a lot of Russian T2-MI packages.
I am clearing 4,000 TV channels plus feeds from 50 east to 31.5 west with no Ethernet connection that'll do me :):Y
I am most impressed with the Edision primo IP S2 :lol: A very Big Thank You to our sponsor World-of-Satellite:cool:
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
I've put stock firmware back on it and found some "interesting" things shall we say, I will dig a bit deeper!
Looking forward to that.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Firstly, if you flash a new image or do a System Restore, it does not clear the box out completely, it still leaves things there.
Also I found a config file, there seems to be additional stuff in here one can change.
[power]
    first = 1
[log]
    out_put_type = 0
[Video]
    xres = 1280
    yres = 720
    screen = 0
    auto_adapt = 0
    aspect = 0
    auto_ntsc = 5
    interface = 40
    freeze_switch = 1
    sync_flag = 1
    pp_max_width = 1920
    pp_max_height = 1088
    fb_max_size = 47013888
    mosaic_gate = 100
    esv_size = 4194304
    support_ppzoom = 1
    resoluton_hdmi = 23
    resoluton_yuv = 8
    resoluton_rca = 1
    resoluton_rca1 = 1
    resoluton_scart = 1
    resoluton_svideo = 1
    brightness_hdmi = 50
    brightness_yuv = 50
    brightness_rca = 50
    brightness_rca1 = 50
    brightness_scart = 50
    brightness_svideo = 50
    saturation_hdmi = 50
    saturation_yuv = 50
    saturation_rca = 50
    saturation_rca1 = 50
    saturation_scart = 50
    saturation_svideo = 50
    contrast_hdmi = 50
    contrast_yuv = 50
    contrast_rca = 50
    contrast_rca1 = 50
    contrast_scart = 50
    contrast_svideo = 50
    auto_pal = 1
    stop_freeze = 0
    dec_timeout = 3000000
    userdata_enable = 0
    userdata_length = 1024
    mosaic_drop = 2147483647
[AutoPlay]
    video_name = player4
    video_url = logso.bin
    radio_flag = 0
    play_flag = 0
[av]
    spdif_config = 0
    audio_level = 1
    mute = 0
    scart_config = 1
    rf_mode = 0
[Audio]
    ac3mode = 2
    track = 3
    ac3enable = 1
    aacenable = 1
    anti_error_code = 1
    dmx_full_gate = 1024
    interface = 14
    spd_source = 4
    hdmi_source = 4
    volume = 50
    volume_priv = 0
    downmix = 1
    sync_flag = 1
    speed_mute = 0
[Play]
    packet_cache_size = 10485760
    network_cache_size = 6291456
    play_support_nds = 0
    play_error_stop = 0
    delay_cache_size = 16777216
    delay_hw_cache_size = 2097152
    delay_cache2memory = 1
    record_cache_size = 3850240
[time]
    zone = 0
    summer = 0
[osd]
    trans_level = 230
    infobar_timeout = 3
[lock]
    menu_lock = 0
    channel_lock = 1
    boot_lock = 0
    stand3hours_lock = 0
    password0 = 48
    password1 = 48
    password2 = 48
    password3 = 48
[coordinate]
    longitude =
    longitude_direct = 0
    latitude =
    latitude_direct = 1
[pvr]
    duration = 0
    tms_flag = 0
[PVR]
    record_volume_sizemb = 2048
    shift_flag = 1
    shift_dmxid = 0
    shift_file = /mnt/usb0_1/shift.ts
    record_volume_maxnum = 0
    record_volume_fullstop = 0
    record_reserve_sizemb = 20
[subtitle]
    mode = 0
    lang = 0
[FILE]
    ets_encrypt_flag = 1
    ets_encrypt_len = 8
    ets_encrypt_key = gxspd123
[end]
    end = end
I Factory Reset mine ..... it retained the latest Firmware I'd installed, but reset all the customisation ..... good job I had the foresight to do a Backup before playing!
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
If anyone on here has a box that's never been flashed with alternative firmware let me know, I'd like to check something...
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Finding some hidden webpages on the built in webserver:
http://box ip address here/readers.html
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Are you still interested?
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Thanks for asking, I figured out how to restore the box completely to the factory firmware
so I don't need this now, I put a thread up on here on how to do it if you ever need to do the same :)
