40.5W SES6 & NSS806
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
? on the Hellobox.. ?
what's it?
thanks
antrabe
dreambox7080 dm900 viark droi
spain
i can lock espn with 1.8m and titanium lnb from soth of spain 9.30db works really good
antrabe
spain
Somebody can lock disney frec
3843.00L22HemiDVB-S28PSK300008/9
because with satfinder i can lock 89/72 strong/Q but i cant lock with dreambox8000
Yes, I locked it with both Zinwell LNB and Titanium LNB using Dr HD F15 receiver. I have attached a picture below of the scan result from 40.5W in C band comparing the Zinwell LNB with the Titanium LNB.
antrabe
spain
which ziwell are you using i have 15k but titanium works better for me but its strange dreambox cant lock with such signal
I have attached a picture of the type of Zinwell C Band LNBF I used for the test. Please note that I did not use the dielectric plate in the Zinwell LNBF for the scan test result I have posted above (reply 106) , I placed the Zinwell in a polo pipe.
For another test I compared the two setups listed below:
1. Zinwell LNBF with a dielectric plate and no polo pipe
2. Zinwell LNBF placed in polo pipe without dielectric plate
The Zinwell LNBF placed in the polo pipe (test 2) gave the best results, stronger signal levels and more transponders.
antrabe
spain
with titanium and policarbonato dielectric 40 tp locked i think there is on sat 43 good results with titanium.
The zinwell is different is 15k and 67db gain
In the table I posted above I got signals from 75 transponders from 40.5W. However, some of them may have been feeds as I did the scans on different days.
If a dielectric plate is used, the Titanium is a better LNB than the Zinwell. If a polo pipe is used without the dielectric plate there is not much performance gap between the Titanium and Zinwell, the Titanium just has the advantage.
Not a feed but LeMans on Fox Sports 40W CBand 4095 SR30000 PowerVuP1010034.JPG
I have attached a table below that presents some signal levels from 40.5W measured using different scalar ring positions along the feed barrel and different distances of the feed barrel from the dish.
Dish = Precision 2.0m prime focus, focal length of 755mm
Feed = AV-COMM polo pipe
LNB = Titanium PLL LNB inserted into polo pipe
Receiver = Dr HD F15
The table shows some trends suggesting the optimum feed distance is ~ 745mm to 750mm but also contains an anomalous result suggesting the optimum feed distance is 755mm.
Great reference table MB. I also find the skew between those frequencies differs somewhat.
Yes, I am not quite sure if there are some artefacts being introduced by the polo pipe in the process of transforming the circular wave to a linear wave. A repeat of the test without the polo pipe using just the LNBF with a dielectric plate might be informative?
It sure would MB
During my various signal level tests on 40.5W I noticed a transponder with an unusually high FEC. The 3843L transponder is in DVB-S2, 8PSK and FEC 8/9. It is not a feed, it is a regular broadcast. The signal level required for a lock is around 10.7 dB.
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
must be written to Lyngsat, Flysat :cool:
ncorrare
WaveFrontier T90.
SelfSat 50 with HH90 rotor
Linux / TVHeadEnd
2x TBS6981
2x Cine S2
CM23
I've been meaning to get this bird for ages. What is the absolute minimum dish size to lock on it? (South of England, near Cambridge)
I've seen EIRP numbers which would put it as low as 1M, but I know YMMV.
pride21
Sandown Isle of Wight
hi moonbase i see people getting ESPN on 3980L on 1.8cm and yourself on 2 mtr dishes i thought i would try my luck on my 1.5cm gibby and here is the result
