OCTAGON SF8008 E2 4K UHD
maxi_power
120cm motorised dishes
PT
With USB drive I did not test, but with sdcard I tested simultaneous recordings on both tuners without problems.
ja5on
Vu+
england
Im having problems with my diseqc switch and cant lock channels, also poor snr and agc
Strange 1 diseqc switch works fine and the other doesnt. Iv read there was a issue like this some time ago but think it got sorted.
But Everything works on my Vu+ solo se
Any ideas ??
http://www.octagon-germany.eu/
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 15.05.2019
- Add GPT usb disk support in fastboot
- Change the default bootargs in fastboot for sf8008
- So it can enter recovery even lost bootargs partition for sf8008.
- Try to fix DVB-T2/C SNR value for ATBM78XX demod.
- Disable the VFD display when go to deepstandy.
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
Tururu
Assembled with recycled parts
Recycled as the owner.
Has anyone experienced crashing on this box when recording to a USB drive? Me and a friend both have this receiver and tried recording the Eurovision feed on 7E last night. Both of us experienced a box hang and had to flick the power switch to get it back, obviously ruining the recording. The feed was high bitrate and 4:2:2 but never had this issue in the past with other receivers. This was using the latest OpenVix image.
Recommended usb with high transfer rate.
If you use a bad one, record at 6Mbs second, as we want to record an HD event (high bitrate), like the Asika kika HD channel at 19'2ºE that can have 14Mbs. second for example.
I do not have this receiver, but in others something similar happens.
Recomendados usb con alta tasa de transferencia.
Si usas uno malo, graba a 6Mbs segundo, como queremos grabar un evento HD (alto bitrate), como el canal kika HD de Astra a 19'2ºE que puede tener 14Mbs. segundo por ejemplo.
No tengo este receptor, pero en otros pasa algo similar.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
no crash with recordings here, post your crahs logo pls.
Thank you. I've had 4 of these crashes this week, as has my friend. We recently discovered that its not limited to recording, simply even viewing the Eurovision 4:2:2 feed over VLC (from Openwebif) has caused the box to hang.
I have attached my crash logs.
  • logs.zip
MIS/PLS LCN Scan Plugin Test SF8008
- 5West MIS/PLS Scanner Plugin mit Auto Bouquet für Fransat & Italia
- 5West MIS/PLS Scan Plugin with Auto Bouquet for Fransat & Italia
Danke an den macher.
Thanks to the maker.
Siehe Bilder auf Octagon SF8008.
See pictures on Octagon SF8008.
more tests
some more ..
Laser
Thank you. Presume you need to download a plugin? Anyone tried it? Whats it called if you have?? Thanks
MCelliotG
Thessaloniki, Greece
It's a plugin available on OpenATV for all MIS capable receivers, I don't understand why it is led to believe that it's SF8008 specific....
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 21.05.2019
- [sf8008] define subt and teletext abnormal pts diffs
- DVB Untertitelwiedergabe bei aufgezeichneten Sendungen
- DVB Subtitle playback on recorded programs
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
General question about E2 and receiver with antennas as this Octagon.
Is it possibile, using tha LAN, to activate the wifi on the decoder as an HOTSPOT?
thanks
Pierangelo
samiDZnoor
YahSat+Astra
ALGERIA
MIS/PLS LCN Scan Plugin SF8008 not only for OE Alliance based images ,it's available on 8 panel too and works well on OPEN8EIGHT6.x IMAGE wich it's PLi based .
buaswe
Sri Lanka
- 240 cm Prime
- 130cm Patriot Offset KU & C band ready
- 90 cm
- 3 x 65cm offset Dishes
- sf 8008, 2 x Freesat V7 HD , 2 X Dreambox 500 , Dicksmith
- Windows XP ( Still Love this ) , MAC Mini
Kandy, Sri Lanka
Can you help me with Airplay setup in receiver .
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 01.06.2019
- fix timeshift skip
- improve the function that get PTS from decoder. the right PTS using for timeshift and PVR playback
- change frontpanel driver for led and 4x7led according to the new setup menu of display
- add new frontpanel controls need new e2 updates
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Hi I would like some help in restoring my Softcam plugin because I did a normal daily update and the plugin (where to switch the Softcam on/off
disappeared. I tried a new install but I could see no plugin. I am using Open atv Image.
Has there been a 'daily update' for this model lately ?
The Octagon website has all other receivers in the support section, but not the SF8008 (in any tuner version).
