OCTAGON SF8008 E2 4K UHD
Laser
SF8008 - 65 updates today. Seem to be some every day nearly. Most not apparent what they are!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Look like that Open ATV removed its sofcam plugin from it's Octagon Images since 14/06/20109.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 21.05.2019
- [sf8008] define subt and teletext abnormal pts diffs
- DVB Untertitelwiedergabe bei aufgezeichneten Sendungen
- DVB Subtitle playback on recorded programs
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
Please from where can I find these drivers ONLY for my Open Atv Image?
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Use this telnet command to get it back ^_^
wget -O - -q http://updates.mynonpublic.com/oea/feed | bash
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Thank you, but what I did was to use an April Open Atv Image which I had in my Documents and flashed it into the box (this Image precedes
the one which had the plugin removed).....but thank you I made a note of it for future reference.
http://www.octagon-germany.eu/
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 26.07.2019
- [SF8008] Update Drivers:
- [sf8008] update dB info ATBM782x (DVB-C/T2)
- [sf8008] add dB info for ATBM782x (DVB-C/T2)
- [sf8008] calculate Signal Quality int.SNR % dB (frontend)
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Does anyone know if power to the motor is still received when the box is in normal standby mode? (or is this something that is relative to the image itself?)
I'm using OpenVix and have been putting the receiver into Deep Standby every night after use, just in the worry that the motor is not powered down completely when using the normal Standby option. Can anyone confirm this? I've had 2 TM motors completely die in 3 years so want to try and preserve my current TM-2600 in any way I can :D
Not got the box connected at the mo, but think it powers the LNB voltage down in standby, If you have a voltmeter you could see if the voltage drops from the LNB socket in standby.
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 14.08.2019
- add support for Blu-ray LPCM
- fix a bug for DVD LPCM
- support for 32bit/8bit/24bit depth PCM audio
OCTAGON GERMANY SUPPORT
maxi_power
120cm motorised dishes
PT
This is not normal, mine is almost 10 years always on.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
Thanks guys.
I've noticed that on OpenVix, changing the front display settings via the settings menu isn't actually working with the box. I changed it to show the red LED on standby, no LED on deep standby and on clicking green to save the options, they never seem to take affect.
dankargo
Brentwood, UK
90cm Motorised
Brentwood
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 06.09.2019
- The updates for "wake on lan" (WOL) function.
- Networking Update
- Hihalt Update
- hi_pmoc.ko & hi-dvb.ko Update
Please see my above post. Is it fixable? Even with red standby light selected in Front display options, the light remains blue on standby.
The original firmware that came with the machine here (DVB S / T tuner) has a red light on standby.
Octagon might have run out of red LEDs
New firmware, and I'm still getting the red light on standby.
