New edision os mio+ 4k s2x + s2/t2/c
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Has anyone discovered the new Edision OS Mio+ yet?
It looks like a good receiver, Price/quality. But is it?...
It has a triple tuner, one S2x multistream, one S2 and one for T2/C.
The display looks quite good and displays the channel name (which I like because it looks quite high end)
I've got the Edision Primo and it's a good receiver, but it has some nasty bugs... Whilst Edision don't want to update the firmware anymore.
There are two bugs which annoy me:
- The subtitles on some of the HD Channels, aren't shown completly (only the upper line appears) (strange enough, on the german HD channels (19.2e), no issues.
- The recording function isn't always reliable!
So... Knowing this, I am wondering if someone has the new Mio+ at home and can tell me something about it.
Is it as simple as with the Primo to integrate the Spanish TDT into the channel list, or is it like the Octagon sf4008 where you need to install some sort of "scripts" into the receiver?
The Mio+ looks like a high-end receiver for a fairly good price at +/- €180
Anyone who has more information about it?
Thanks in advance!
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
You need a USB stick of at least 2 gigabytes to flash the firmware.
Otherwise, it is an Enigma 2 receiver, you can search in google with these words:
"It's necessary to have installed astra-sm, add "astra-sm",go to etc/astra"
p.s.
don't ask me why on this forum
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
p.s.
Thanks for this info,
What is the standard firmware?
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Is this receiver better in some way than the Octagon SF8008 ?
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Hi all,
I've purchased this receiver and I already ran into multiple problems... I hope someone can help me.
Openatv 6.4
When going through the installation wizard, the box asks the picture quality. Because I have a 4K TV I want to set the picture quality to 2160p. But this makes te image (especcialy the OSD text) very bad.
I get beter picture quality by setting it to 1080p (I also had the same problem with an octagon sf8008 (with openatv) and on another 4K TV so it's definitly something with openatv, i presume)
Wanting to install an oscam, i've downloaded an ipk file. When I install it, the receiver gives me a "succes" and no error but the option "oscam" won't appear in the menu so something must have gone wrong, I have no idea what...
After installing this oscam ipk file, the receiver craches when trying to make an automatic or manual transponder scan!
So i completely installed openatv on another slot and began again from scratch. This way, I knew it was the ipk file that caused the crash while trying to scan.
After i've been through the installation wizard again, I wanted to make a back-up to a USB device but I have no idea how it works... Doing a complete back up will take up to 15 minutes says the receiver but I see nothing happening.
I've wanted to make a back-up only for the settings so I only need to flash a new image and use the back up to have just my settings back.
I am completely new to e2 receivers and I don't have High expectations of it. The only thing I want is to get an oscam working (abertis)
I already have my channel list from my primo receiver which was much less complicate!
The only thing i've learned is that you have to set a password in openatv in order to reach the receiver using e-channelizer or another ftp client.
In short, my problems are;
Picture quality 2160p bad (like an old sd channel) whilst 1080p good
Getting an oscam working
Making a back-up in case is Screw up the receiver
Is there someone who has more experience in this?
Rather than install an oscam ipk file you could try downloading oscam from the receiver menu Plugins section. There is an option to download plugins from a server which is likely to have the correct oscam version for your receiver and image.
After downloading oscam from the server or installing it from an ipk file you might still need to FTP a set of Config files to the receiver. It depends on the contents of the ipk file or the server download if a set of config files was included.
Without the config files oscam will probably not be operational. The usual location to FTP the files to for a mio 4K is /etc/tuxbox/config but it might possibly vary depending on the image.
To check if oscam is installed correctly you can use the WebIf interface of the receiver to see if it is listed in the left hand pane under the Extras section. You can also use the WebIf interface to edit the oscam setup if required.
To delve any deeper into the functionality of oscam is possibly getting beyond the allowed scope of discussion on this forum, it could be approaching the grey zone.
There is an option somewhere in the menus of the receiver to make a full backup of the current status of the receiver to a USB stick.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Hello Moonbase,
I played with the receiver, the last weeks to get it set up to my wishes.
I have 2 questions;
1) How do I configure the Oscam Emu so the discovery channels on 4.9e and 0.8w are descrambled? I have the correct keys but the creen stays black.
2) About abertis; I'd like to add some radio channels which are not in the latest files you can find on the internet. But the "how-to" manual was deleted from this forum because of all the begging for keys... So I am a little lost about it. I would like to add all the "los40" versions and also Cadena Dial. But I don't know how to correctly doing it without srewing up what I have achieved on the other channels...
Can you or someone on this forum give me a little hand?
I thank you all so much!
Hello Moonbase,
I think you may be venturing into a discussion area that is beyond the permitted scope of this forum?
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I don't know... maybe... But I won't need any need for keys. Just settings. If it is not permitted on this forum, I am sorry, then the admin is free to delete this posts.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Hi all,
It's been a long time since i've had my receiver. I've set it up the way I want, except for one thing.
When I instantly want to record something, I want to push the record button and the receiver should instantly record. Now I get a lot of options that I have to choose for.
I just want instant recording and when pushing the record button for a second time, I want to be able to set a specific time for the recording.
And last, To stop the recording, I want to use the "stop" button (the rectangle)
I know there is a way in some sort of spreadsheet to edit the functions of each button. But I don't know where to find it on the receiver, and I don't know how to change it with the right parameters.
I use OpenAtv 6.4 which works fine for me.
Thanks for the help!
LeBelge
Belguim
I never recorded anything with the remote control.
Sometimes I record with VLC on the computer, then the file can be read by other computers.
Open with VLC and record
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Thanks for the information, but this was not the answer I was hoping for. I would like to edit the function of the buttons on the remote. (via keymap.xml)
Manikm909
Small'ish Dish Man
Kent, UK
when you hit record it DOES start recording, but it gives you the options you may want i.e to set the duration beyond the programmes time that you are watching - this isnt a problem in my view.
if you setup a timer recording, then there are no questions asked (obviously)
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I want to set this up more user friendly because I have to explain this to older people.
if they push the record button, it should start recording, no questions asked. If they push the STOP rectangle button, it should stop recording, no questions asked.
Normally it should be possible, at least, I can't imagine it won't be possible...
I thought some people here on the forum would have experience with editing the keymap.xml file.
I can't seem to configure it the normal way with the set up of hotkeys...
Manikm909
Small'ish Dish Man
Kent, UK
enigma2 is an enthisiast's OS (not for amateurs) - the record button is working correctly - get a non E2 box, if you want to keep things simple
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
That's besides the question... Enigma2 boxes can be modified "à la tête du client" so you can make the box as complicated, or simple as you want.
Manikm909
Small'ish Dish Man
Kent, UK
i dont think its besides the question at all - the instant record button is working how it is intended, it has ALWAYS been like that with E2 - it just gives extra options, whats wrong with that ? would you really want your hard disk filling up if you forgot to STOP the recording because thats what would happen if the extra options didnt show up.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
I never said that the record button doesn't work the way it should.
enigma2 boxes can be modified in different ways, you can customize the image the way you want and you can change every key on your remote, the way you want it.
My question was how to change those key bindings so that when I press the record button, it starts recording and when I press a second time it gives me the options. Because now, with OpenAtv 6.4 it only starts recording after you selected the different options.
In short, did anyone here on the forum has experience with changing the keymap.xml?
If the record button works fine for you,... Happy you...
Manikm909
Small'ish Dish Man
Kent, UK
happy me indeed.
