Logged out after each visit to forum
pontiend
Contibruter
south yorkshire
Nope that one has gone to moderating.
And this has.:)
That one too is waiting for moderating.
Give me a chance! I seem to be the only one on duty ATM. And I'm going out soon to go shopping.
And this has.:)
As I said, all non staff posts need approval even if you're logged in.
Going out now so I'm not sure who's available to take over.
Journey
drx 890
I haven't noticed that Https wa
I hadn't noticed that Https wasn't present. It is now. Any idea how long that happened for?
Paul, my memory is shocking but I'm thinking monday/tuesday perhaps
EDIT:- https back for me now - ty
You wouldn't normally see that message as you don't normally post in this section. You have to be logged in for the other sections so wouldn't see such a message by definition.
Laser
Same here. OK on the I pad but PC keeps asking for password!
4wd
Getting the picture
5 W, 9-13-19-28 E
Autofill of user & pw in browser (firefox) stopped showing up.
Had to delete the saved info and reenter it, seems ok therafter.
Edit: wrong, asks for for username and pw again, even if they are properly saved in browser.
aceb
Prof Tuner 7301 /
Sussex
Pretty much the same for me - latest version of Firefox and Win 10 Pro on both machines with which I access the forum.
Snap, on all counts. One of my other forums does the same when I log in from a different device.
4wd
Getting the picture
5 W, 9-13-19-28 E
Am on a bunch of other forums, problem is only here, and started recently.
Same result trying different browsers, duly saved login data not showing up, must be entered manually each time.
I have moderated about 7 posts awaiting approval today by members ? what is going on,
I am using Firefox latest update with no problems here atm.
Just in this thread or elsewhere as well?
Then this is the reason.
It's because this section is open to all for posting without logging in. If you have problems logging in then you have to be able to post somewhere about it! In order to keep a lid on any spamming every post that's not by a member of staff needs approving.
If it's the post by ManFromWales it'll be because he's a new member with a low post count.
4wd
Getting the picture
5 W, 9-13-19-28 E
About my login case, turned out was due to my (very old) stored link was http instead of https, some kind of recent forum update\change now very probably forcing the use of https for saved logins.
4wd
Getting the picture
5 W, 9-13-19-28 E
^^^ May I suggest that a http redirect is implemeted to force the use of https (.htaccess).
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Not been around all yesterday but have been logged in all that time with Win 10 Chrome and sleep mode, did not have to log back in and using https everywhere without a problem so I can only assume @chris has tweaked something to correct the issue.
