New tp active on 37,5w?
dishdx
www.dxing.cz
Showbox Vitamin, Octagon SX88
Dishes: Offset motorised 120 cm 40W-75E IBU Twin, Channel Master 180 78.5E-30W manual rotate , Cahors BigBisat 8 x Alps 1W,5E,9E,13E,19E,23.5E,28.2E,39E. Planty of equipments for FM and AM DX. http://www.dxing.cz
Central Bohemia
Hi!
I have found TP 11613 H, SR 5915. My signal is bad, because of house in direction, but this freqeuncy seems to be active a few days and it is probably not feed. Unfortunatly I can´t see picture, only fragments, in left corner is probably some logo. Can you please check this frequency and write what is on? It is not listed on flysat.
DishDX
SatSearcher
West Yorkshire
It's not signal strength that's the problem, it's because the stream type is continous (not transport), most equipment can only make out extremely blocky images from this stream type. I can see it myself, from the bits of audio I can make out it definitely sounds dutch, and I can make out a '4' in the top left corner, so presume it's RTL 4, but that's as far as I can get with it.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Do you know if it is an occasional feed for a television show or is it to feed the RTL4 channel for cable networks (and so a continous feed) If you know what I mean?
SatSearcher
West Yorkshire
I couldn't say for certain, a lot of these types of signals seem to come and go quickly. If I have time later I'll look to see if it's still active.
dishdx
www.dxing.cz
Central Bohemia
This signal is active ca. since 6.4. when it has appeared in scan resolution in EBS. Yes, the sound shoud be dutch.
dishdx
www.dxing.cz
Central Bohemia
Now I noticed NPO Logo. Better "quality" is in POT Player.
dishdx
www.dxing.cz
Central Bohemia
And second station is really RTL4
dishdx
www.dxing.cz
Central Bohemia
Ziggo in the stream
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Nice!
I Would love to know the purpose of this transmission! :-D
A shame we can't decode it properly. I suspect there is no domestic equipment capable of decoding the stream.
Nice!
This type of transmission is the same as usual,but,as they say,with other means.But it is cheaper,because it can transmit more streams(encapsulated) at the same time.Some are FTA, like the one in the pictures,some are coded.
Indeed they can be decoded only with a dedicated equipment,which the beneficiary has.
