- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Frequency re-use on 9B might scupper that plan. 12111v in use on both italian & nordic beams.
Keep us informed if you manage to get those channels, i'm quite interested!Yes, the downlink levels will be similar in this part of the world, but the two transmissions have different parameters, plus there should be a very small difference in the polarisation skew settings that a polarotor can further separate.
What does this mean 5w will stop broadcasting soon? Will BIS move to 13e?
They don't need extra capacity at 5w anymore, why would they invest in another bird?I find it difficult to believe that Eutelsat has no birds to temporarily place at 5W or borrow one from another operator.
according to lyngsat not.I'm trying to figure out why the signal on 11138V and 11512V dropped so much at my location, while it is still strong on 11596V, 12690V and 12732V.
It could be that they moved 11138 and 11512 to 5WB already ?
But because the old bird is inclined 0.7 degrees that could be the reason why you have lower signal levels?
12.08.2020
Moved 11138 and 11512 to new 5WB
