Jaeger smr 1224 adjustment-overhaul-maintenance
cardiff
Brittany
Laminas As 1800, multifocus 14 LNB
France
Hello everybody,
Back on an old thread on the restoration of a SMR 1224 (restoration / modification Jaeger 1224 - SatsUK)
Jaeger 1224 restoration/modification - SatsUK
make by RimaNTSS but he does not remember exactly the details of the modifications made 6 years ago.
he said:
"all the gears have been removed to tighten them" how to tighten them ?
the 2 parts with the gears with 4 screws added to tighten the gears
There are also the 2 red Allen screws what are they used for?
I also have the magnetic wheel that I tightened several times, I think there is a little "play" with this magnetic wheel, there is a very slight shift in the number of pulses, it would come from all gears?magnetic wheel.jpg
do I have to dismantle everything to check! (to see pictures) ?"
Thanks to everyone who can give me answers
Cardiff
Trust
Nijmegen Netherlands
Hello everybody,
the 2 parts with the gears with 4 screws added to tighten the gears Its all about those 4 screws I think , just check they are tight
There are also the 2 red Allen screws what are they used for? Behind those red screws are springs , they put tension on the worm axel to the worm wheel
Dont put to much tension on that wom axel , it can break
They should stick out 1 mm or are even with that block
I also have the magnetic wheel that I tightened several times, I think there is a little "play" with this magnetic wheel, there is a very slight shift in the number of pulses, it would come from all gears?View attachment 131204
I dont think the miscounts is done by the gears , maybe the distance between the reedswitch and the swinging magnetic wheel .
do I have to dismantle everything to check! (to see pictures) ?" If those 4 scews are loose and you can move that motor gear part a little apart from that big main gear , both plastic covers need to be removed
Cardiff
Is this the motor from Rimants ?
cardiff
Brittany
France
Thank's for all your precise and complete answers
Yes, this is the SMR 1224 from Rimants , I told him about it because I used the pictures from his thread Apr 6, 2014
Thank you
Cardiff
cardiff
Brittany
France
Hello,
I'm looking for where exactly are the metal slats positioned around the mechanism of the Jaeger SMR 1224?
I found 9 metal slats by dismantling the SMR 1224.
(I disassembled it a few months ago and I'm reassembling now)
3 are known as shown in the photos.
others ?
Thank you to all who can answer me.
Cardiff
Trust
Stick 3 slats together on the 3 rims if I remember well
cardiff
Brittany
France
Thank you Trust
I believe there are in these places but I am not sure.
on this 2nd picture we can see, but i'm not sure !
Cardiff
Trust
The other picture of the bottom plate with the 3 red arrows shows the right place
anto@
italy
after disassembling the smr 1224 engine i decided to restore it with a new paint, the engine was repaired in 2015 after a breakdown replacement of the hardware with steel bolts, I still have to finish it but I'm on the good road
cardiff
Brittany
France
Hello,
I knew something was wrong with my Jaeger SMR 1224 After cleaning the worm
I discovered that it was about to break. In addition this worm is very hard to disassemble and I did not succeed.
I'm looking for someone who could find a solution to fix it or fix it for me.
Thank you all for your answers
Cardiff
cardiff
Brittany
France
Hello,
The broken worm has been repaired by Trust (golden hands)
I thank him very much.
The 2 equally defective ball bearings have been replaced.
The spigot has also been replaced since I had to drill it. Also made by Trust .
Now everything is going well
Cardiff
dreambox1959
46.3N-4.3E-FRANCE
france
good news , we can go on ! i have made some improvements on my positioner program .
