Octagon sf8008/sf8008m mini multiboot with octagon sx88 linux os
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
Thank you f
follow this video
or
follow this video
Thank you for video But sorry I am not understand
In video he explain only how to recovery by usb emmc that I under stand
Also in video he explain about how to upgrade by network that also I under stand
The question if I want to upgrade by usb how will be the way
and that way need to connect the device with earthnet cable ?
I have very low experience in E2
If I make noise for you plz tell will stop asking you how to do
Sorry
Thank you
All the best
SnelleJef
Triax 88 Inverto Black Ultra Lnb And The VU+ Zero 4K
Belgium
first make sure you have for example openatv on it then it will work easy to flash to another image thats how i did it take your usb stick and format it in fat32 download octagon-sf8008-v1.05.23-20200622-mmc and copy it to your usb stick dont unpack it just put the rar file on the usb put the usb in the usb 3.0 hub on the right side close the receiver and hold power button until you see updt then wait for the screen to show from there choose usb network multiboot and choose what image you want and download it and wait til the install is done and boot your new image also if u want define choose slot 4 and on slot 2 choose openatv you can delete any image afterwards goodluck
http://www.octagon-germany.eu/
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10525 01-07-2020
Changes:
1. Browser Update & Fixes.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10523 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10523 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10523 OK
SW offline - USB:
DUAL OS Menu: octagon_SF8008_v1.05.25_20200702
Recovery Bootmenu (E2):
SF8008 - MediaFire
SF8008m - MediaFire
OCTAGON GERMANY SUPPORT
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10526 13-07-2020
Changes:
1. Touchpad WEBIF Android and iOS.
2. Voume Control steps improved.
3. Keyboard Support YouTube.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10526 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10526 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10526 OK
SW offline - USB:
DUAL OS Menu: octagon_SF8008_v1.05.26_20200713
SF8008 & SF8008m mini- Recovery_Menu_SF8008-SF8008m_140720
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10527 30-07-2020
Changes:
1. Fixed some MKV cann't play.
2. Hi-Player .lib upgrade.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10527 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10527 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10527 OK
SW offline - USB:
campag5242
Dishes: TD110, TD88
Receivers: SF4008, SX88, Samsung TV
NW UK
Thanks for this, it's like having a whole new receiver for free.
I was keen to compare the blindscan of the SF8008 running this SX88 derived "Define OS" against an actual SX88. It's much slower (it hung for ages on 7E near the end of the H half of the scan whilst the SX88 races on ahead), but pulls in low SR transponders which the SX88 cannot.
The IPTV side looks very much improved over SX88, but that's not something I use. It's a shame for us satellite enthusiasts the same effort isn't being put in to the satellite features in this bianbiang (SX888) & out.elf (SX88) dvb app.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
You mean the newer SX88 4K can get lower SR's than the SF8008 ? not lower than 250k though ?
campag5242
Dishes: TD110, TD88
NW UK
No, my comparison was SF8008 running Define OS versus the old SX88.
I haven't tested Enigma vs Define performance running on the same SF8008 hardware.
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10529 27-08-2020
Changes:
1. SAT-IP Client app added.
2. Clear Browsing Data added.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10529 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10529 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10529 OK
SW offline - USB:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10530 16-09-2020
Changes:
1. update os. to latest version.
2. modified bigger font size for subtitle.
3. modified SID numbers limit for bis.
4. improved SAT>IP function.
5. modified the subtitle position.
6. browser some minor bug fix.
7. some osd bugs fix.
8. Delete ALL channels freeze & hangup problem fixed.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10530 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10530 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10530 OK
SW offline - USB:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10531 27-09-2020
Changes:
1. Option Menu extended.
2. DVB CH. List INFO Button added.
3. Media added to Hotkey.
4. Minor issues fixed.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10531 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10531 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10531 OK
SW offline - USB:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10534 31-10-2020
Changes:
1. TV Online added.
2. Update latest OS Version.
3. Force Upgrade function added.
4. Fixed some bugs.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10534 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10534 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10534 OK
SW offline - USB:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10537 06-12-2020
Changes:
1. Default sort by number for Stalker - Option Button.
2. Add. User Agent for Stalker - Stalker Option - System.
3. Modified ATR of for Slovakia.
4. Disable change freq of GPU.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10537 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10537 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10537 OK
SW offline - USB:
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10538 25-12-2020
Changes:
1. Fixed audio(EAC3) descrambl edelay after boot bug.
2. Fixed HDR Auto not work.
3. Fixed sometime the sort function of stalker not work.
4. Fixed PVR + TimeShift bugs.
5. XT User Agent add.
6. Fix MultiTS.
7. WiFi 8192CU fix.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10538 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10538 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10538 OK
SW offline - USB:
SF8008: octagon_sf8008m-v1.05.38_20201225_mmc
SF8008m: octagon_sf8008m-v1.05.38_20201225_mmc
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10539 02-01-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. Fixed Tuner 1 not work
2. Fixed SAT-IP client not work
3. Fixed user agent wrong format
4. Abertis fixed.
5. 2 Decode Support
6. Fixed long EPG name in EPG Menu
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10539 OK
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10539 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10539 OK
SW offline - USB .mupg:
Recovery Bootmenu MMC (E2) SF8008 & SF8008m:
Adam792
Cheltenham
4. Abertis fixed.
I'm running V10539 on my SF8008 mini. Not sure what this fix refers to specifically, but Abertis isn't working completely in this version.
The lower bitrate streams work fine (e.g. 11222H, 11347H), but the PIDs that contain a full 20Mbps multiplex (e.g. the three streams on each of 12548V/12631V/12671V) break-up and glitch, like the processor is struggling to buffer the decapsulated TS data quickly enough.
I found some 85+ updates for the SF8008 last night, though I'm sure I checked less than a fortnight ago. Perhaps one of those has improved things.
Adam792
Cheltenham
Thanks, a reboot seems to have fixed the issue I was having in the end, and they all play nicely without glitching now.
