New: octagon sx88 4k uhd s2+ip
Any joy with low symbol rate transponders? The primo I have doesn't do anything below 1500sr.
http://www.octagon-germany.eu/
Firmware (Software) Update V10527 01-07-2020
OCTAGON:
SX88 4K
SX888 4K
Changes:
1. Browser Update & Fixes.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10525.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10525.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10525'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88 4K:
SX888 4K:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
galway
motorised and mutli sat
IRELAND
OCTAGON:
SX88 4K
SX888 4K
Changes:
SX88 4K:
SX888 4K:
Online güncelleyin!
A lot of updates in a short time! It does not say which bugs are 'fixed' like if the Diseqc 1.1 issue is solved or it can handle TLS.
2 problems with the SX88 4K :-
1/ DiSEqC 1.3 USALS when I turn off the power at the mains then switch it back on the motor does not move, so I have to tell the motor to go to position then it moves to any satellite that I choose :eek:
2/ The remote control is not designed ergonomically with the Satellite selection button in the bottom left corner of the RCU so I use the SX88 Optima remote with the satellite button within easy reach of my fingers.
Apart from that I am very pleased with this box.
galway
IRELAND
Seems that this box has issues with Diseqc functionality- not just 1.1 as I mentioned previously but also USALS. I wonder if the latest update sorted out the 1.1 issue - I sent box back so can't tell!
Can the box now handle TLS for Abertis DTT?
Firmware (Software) Update V10528 13-07-2020
OCTAGON:
SX88 4K
SX888 4K
Changes:
1. Touchpad WEBIF Android and iOS.
2. Voume Control steps improved.
3. Keyboard Support YouTube.
a.) Installieren Sie die aktuelle Firmware v10528.
a.) Install the latest firmware v10528.
a.) En son yazılımı v10528'i yükleyin.
SX88 4K:
SX888 4K:
Online güncelleyin!
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
My Azbox ME decodes 4.2.2 !
Yes so does mine but not in MPEG-4 DVB-S2 this is what the majority of feeds use now so the AZBox is obsolete,
The latest patch for the SX88 4K: does not address the problem of DiSEqC motor settings lost when I disconnect the receiver from the mains,
I can work with it if I leave the power connected but this is not always possible then I have to reset the Motor settings,
Can you fix this Octagon-Germany ?
I do not have this problem with the SX88+ & SX88 Optima or any other receiver so there must be a solution.
Jose67
Technomate TM-Twin oe, Open Vix
Octagon SX88+SE
80cm solid dish, and 70cm for Hispasat 30W.
Fixed diseqc 1.0. X2
OpenWebif, dream Player for Android TV.
North West London.
On the SX88+ is there any way to backup Recover the CA key editor, or even edit manually over the network connection.
galway
IRELAND
Tbh this has not been a good release.... Diseqc 1.1 problems and now seemingly USALS issues. This should have been sorted by now OCTAGON.
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I was set to buy one, not now
Firmware (Software) Update V10529 30-07-2020
OCTAGON:
SX88 4K
SX888 4K
Changes:
1. Fixed some MKV cann't play.
2. Hi-Player .lib upgrade.
a.) Installieren Sie die aktuelle Firmware v10529.
a.) Install the latest firmware v10529.
a.) En son yazılımı v10529'i yükleyin.
SX88 4K:
SX888 4K:
Online güncelleyin!
Mooncamm
1 metre Gibertini dish, Octagon SX88 Receiver
Lincolnshire
So, NO progress AT ALL yet on THE BIG ISSUES that have been repeated several times here - and almost certainly many times elsewhere! :angry:
[/QUOTE
I was going to buy one of these 4K receivers. But I am waiting until things get fixed first. I already have a receiver SX88 that didn't get French sound as the chip wasn't right. A nice 4K receiver well in time for Christmas is in my mind when I see the deal is fixed. :)
Can you fix this @ Octagon-Germany ?
I do not have this problem with the SX88+ or the SX88 Optima or any other receiver so there must be a solution.
I have even started a message with Octagon here that has been ignored ?
I thought we had a good working relationship with Octagon,
Now we have some serious DiSEqC motor & DiSEqC switch problems that have not been addressed with the last couple of software upgrades,
A reply as to when you can fix these problems would be helpful to current owners of the SX88 4K & future customers.
@Octagon-Germany
UNTIL you do fully FIX all those severe issues, then no-one who knows anything about them (and that must be very many by now!!) is going to buy this receiver - so it is in YOUR commercial interest to FIX THEM P.D.Q. ("Pretty Damned QUICK"!):rolleyes:
stephan94
Bavaria
Has this DiSEqC problem been finally fixed?
