Mdr hd 18.7
any one can be recoarder for me on mdr hd on 19.2e
it best schalger live on austeria
Stars am Wörthersee
Sa 18.07. 20:15Uhr 135:00 min
it best schlager 2020
Adam792
Cheltenham
To get someone to send you these the file size for these from 19.2°E must be huge with the high bitrate used by ARD!
Your best bet might be to find someone who receives MDR on DVB-T2 in Germany! It's 1080p but in HEVC with a much lower bitrate (lower file size recording) because of codec efficiency. :)
In UHD, 2.5 hours is around 1 TB
1080p is roughly 250 GB
So, one hard drive plus postage.
LateAdopter
80cm fixed, 4 position switch
28.2 E, 19.2 E, 13 E, 5 W
Xoro HRS8500, Edision Primo
I think there's something wrong with your maths. A 2GB segment of TS from MDR HD lasts typically 18 minutes. The total would be 15GB
FreesatfromSky
Freesat [Humax HDR 1000S]
Fta(9E/13E/19E/28E) [Fixed Triax TD88]
1.1M motorised satellite dish [unbranded]
Stars am Wörthersee
If you just want the programme,I can record it and transfer it to dvd for you.
Obviously it won’t be in high definition,if that helps,solly
Or i can record it on to a usb stick
Adam792
Cheltenham
From a rough estimate, judging by what I've managed with other ARD HD channel recordings, I think it'd possible to get that 15GB down to just over 2GB by converting the video to HEVC (using FFMPEG, keeping the AC3 audio and subtitles as they are without re-encoding), still at pretty good quality.
I don't mind doing that for this programme! That could even fit on a DVD as a file I guess. :D
it poosible to upload mega upload it better
It will be a 'mega' upload
It's not the maths, but whether Solly requires the file in a similar format as it was uplinked from whoever records it for his pleasure, raw uncompressed video is bandwidth hungry.
Adam792
Cheltenham
From a digital satellite recording, you never get raw uncompressed data, you just dump the already compressed MPEG-TS data from the DVB-S/S2 transponder directly to disk. Dumping the MPEG Transport Stream of MDR HD to disk in its raw transmitted format - the video from Astra in HD is 1280x720p50, in MPEG4 (H264) running at an average bitrate of 12.0Mbps for the video (plus ~1.5-2.0Mbps for the audio and ancillary data - AC3 surround sound, MP2 audio, Teletext, subtitles, etc).
There's some detailed analysis of it here - MDR Thüringen HD - 10891 - Astra 19.2East - DigitalBitRate
From their measurements, they're saying an average hour of MDR HD takes up around 6.8GB of disk space, which matches up with @LateAdopter's ~15GB estimate for 135 mins.
You can crush this down by discarding any unwanted streams (second audio, teletext, etc), and/or re-encoding the video after recording so the bitrate isn't so high (this compromises quality but you can get pretty good results depending on the settings used).
The German public channels use very high bitrates on satellite, I think partly because it's used as the 'master feed' by various cable companies in Germany which re-encode the streams for their networks to save space in this same way.
FreesatfromSky
Adam,would you mind taking up the request?
As I would only be able to record to my satellite receiver hard drive or to a usb stick,which is not what solly wants
FreesatfromSky
Just to test,I recorded from MDR HD last night,just set a three hour timer on to a 16GB usb stick.
Which in real terms is only 14.7GB.
It only recorded 2 hours 26 minutes.
Adam792
Cheltenham
Yep sure, I’ve set a timer to record it!
FreesatfromSky
Adam792
Cheltenham
Recorded! It's 12GB, I can't do anything with the file until I'm at home on Monday but I will figure out a way of uploading it then :)
thanks afor user recoarde for me
next show mdr 8.8.2020
Sa 08.08. 20:15Uhr 180:00 min
please set recoarder on mdr hd
Die Schlager des Sommers - Die Märchenschloss-Nacht
