- May 29, 2009
- North York Moors
Sounds to me like the problem will lie at the F Socket on the IView box.
Either it's poorly connected (dry joint?) to its PCB, or the inner receptacle is slightly too short or even too large in diameter to make proper contact with the centre core of the incoming coax.
Try re-terminating the male connectors with an extra few mm of inner core and try bending that core a little to create better contact.
