Advice Needed Dubai one
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Good afternoon trying to tune into Dubai one but no luck
Any advice thank you
Which satellite?
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Badr4 22130v27500
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Signal readings
Badr4 22130v27500
If you're using the dish listed in your profile, you won't get that TP.
You might get a handful of Horizontally polarised TPs eg 12073H, but that's about your lot.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
How to get it then yes it’s 75cm dish
I'm further south and struggle with a 90cm, 26e gets swamped by 28.2e. You can always try nudging the dish to the west a few clicks with diseqc 1.2 but I wouldn't expect much joy.
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
You need a bigger dish my friend! At least 1 meter!
Terryl
Custom built PC
Below is an active footprint map for that satellite, zoom into your location on the map and click on it, it will give you an estimated dish size needed for that satellite at your location, it will also give you aiming information to help locate that satellite and align the dish..
Thats a little misleading in this case as the weak Badr signals at 26E get swamped by the very high power UK transmissions off Astra2 next door at 28E. The smaller the dish the worse the effect.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Already done that that’s how getting about 40% on 11996
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
What is your signal level on 90cm
The figures really have little relevance as you are in a different location on the far fringes of the footprint and the other Members not only have different dishes, LNBs, cable quality and length but probably different receivers whose "metering" will almost certainly have different characteristics and calibration.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ask you about signal level cause I know you are In one strength above area if you are struggling with 90 cm then I got no chance with 1 meter
Yes, I know but, as stated, other Members reported levels are of little or no benefit to you.
So, if you do get any numeric replies, treat them with caution.
Of slightly more use would be reports from others close to your location and with different sized dishes.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
You are near from Midlothian do you get Dubai one
No - I havent had anything off 26E for years. Not one Ive tried for really since I moved house almost 3 years ago. Many years ago Badr 4 was an easy catch on an 80cm dish in the Borders. I even used to get excellent signals on the hypothetical MBC beam which was supposedly aimed only at the MENA area.
28E is too strong to bother now on small dishes - the bleed over will destroy reception of many transponders
With the caveats already mentioned, and assuming the Edision Primo has similar SQ readings to the SX88+, with a Channel Master 90cm (90cm x 100cm) + IBU single in North East England:
11996h 27500 SQ 66%, 10.3db
12130v 27500 SQ 52% 9.0db
D0EFE141-4736-4540-81D3-0777AC276447.jpeg 22A0923B-4C32-4DB6-826D-7B46CB55EBEC.jpeg
