Advice Needed Dubai one
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Thank you for your time and help
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
What will be the signal on 1 meter for Dubai one
I have a Gibertini 1m dish and I get Dubai One on 40% quality, dropping to 33% when it rains. I suppose it all depends where you are in the UK. If you look at my avatar, that is my dish with Inverto Black Ultra LNB (motorised). By using a smaller dish, it gets hammered by 28E and you have no chance of getting that channel.
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
Ok thank you I am in the same Footprint band so I assume I will get roughly the same on 1 meter
I have a client in Roehampton that asked for the best system available at the time for the 26 East slot, based on the planning restrictions and his curtain twitching neighbour.
So, he has a Triax 110 (we'll ignore the second digit error), and a Qattro - fixed port - LNB running to a small switch. All cable is CT125 and maximum length - dish to switch/switch to receiver is about 15m. Receivers are TM-6800s
To date he is getting around 80 channels continuously, with another 25 or so that come in unless it is raining.
South England though.
speedy_04
VU+ Ultima 4K, gibertini op125l, Inverto Black ULTRA Single 0.2db LNB, Technomate TM-2600 M3 DiSEqC Motor
alloa
Good afternoon trying to tune into Dubai one but no luck
Any advice thank you
as i am in clackmannanshire i am roughly 30 to 40 miles from midlothian. i can get dubai 1 with a signal of 59%. i also get about 200+ channels on 26E. i get a good 72% on 11996 H 27500 and 59% on 12130 V 27500 but i did have to upgrade to a gibertini op125l to get those signals, before on my triax 110TD i would only get bbc arabic around 40%
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
thank you do we need permission to go above 100 cm in Scotland
speedy_04
alloa
you are meant to get permission. i have attached a copy of the planning rules. but as long as the neighbours have no issues with the dish then it should not be an issue. as i have a private landlord he is perfectly fine with the dish being where it is as its at the rear of the property
  • AHouseholdersPlanningGuidefortheInstallationofAntennasincludingSatelliteDishes_id1144586.pdf
Gladstones
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
very interesting that you was getting 40% on TD110 & i am getting 40% on BBC Arabic on 75 cm Gibertini
Comparing signal strengths between different receivers is meaingless. On any particular box its just an arbitary figure. Anyway signal strengths can vary greatly over a few miles in fringe reception conditions. Thread closed - this topic is done
