Eutelsat 9b italia beam
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Reception of Italian beam with 3.4m
RachelM
Ipswich, UK
Gibertini 1.5m / TBS 6903 & Mix Digital Premium TRX 1m / TBS 6903-X
I was really hoping to get the nordic beam with my 1.5m Gibby in Suffolk, UK. But no luck :( Need a 1.8-2m I guess. It surprises me, as 48dBW on the map isn't *that* far from the UK coast.
RachelM
Ipswich, UK
Left it on that transponder overnight, highest SNR being 8.8dB.
0.55dB away from locking. Maybe one day I'll be lucky.
nelson_b
Contributor
That,s a good result with 1.5 m ... but as you say probably 1.8 or above in your area to hold a lock ..... I,m in N.W. U.k 25 miles inland from Lancaster and have only a marginal lock on that t.p. (10.1 db) using a 2.4 M offset Channel master
Kypros_Pambou
Greek Cyprus
Reception of Vianet Package (12227 Ver ) - Nordic Beam from Cyprus
piergabr
Hotbird 13 (4 out)E + Astra 19.2E (2 out) + Eutelsat 5W + Eutelsat 9E - Feeding Sony Bravia and VU+ Zero 4K
Barcelona
The antenna installer has advised me, first, a satellite dish from 1.4 m onwards.
But it does not guarantee the reception of the Italian beam.
Hello, did you managed to have signal from the 9E Italy? I'm in Barcelona and I would like to try but I've a 1.1 m to test it.
Do you think I will be able?
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
1.1 !! no chance iv already tried with 1,2 channel master in Valencia region ..you may be lucky with 2.40m
Pepeyeb
Eutelsat 5 W B con antena de 1m.
Receptor de satélite Octagon SF 8008 twin. Dreambox Two.
Toledo (España)
I have not tried because large antennas are necessary. My wife would leave me and the mayor would think I spied on him.
pipino
Back from the dead
just get tivusat mate .. no more spying problems :D
piergabr
Barcelona
Hi again, it seems Lemmy Morgan from Nigeria was able to receive the 9e italy with a 4m. He is 3000km away from the beam...
I was looking for a new antenna but I can't install a 2.4m.
Any other experience?
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Mind you that in Nigeria you don’t have interference with the nordic beam.
we do.
piergabr
Barcelona
we do.
Understood.
But also in Spain as the beams are drawn we don't have to face the interference.
In the eastern or center Europe yes but in the west south the nordic or Greek beam interference have to be really low, doesn't it?
BTW on teorical hypothesis, do you really think I need a 2.4 antenna?
No-one can answer that question - you could be in a null where you get no signal even on a massive dish like 5m. Or you might get lucky and find you get it on something much smaller. in extreme fringe conditions the signal strength can vary greatly over a few km so even if someone found they can get it a couple of towns over it is no guarantee that an identical dish would work for you.
The only way to find out is to buy the dish and see how it goes.
I am in Bristol and I am unable to lock Nordic beam on 1.8m dish - about 1dB extra required for a lock.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
I have a stable signal on this frequency 12466 V SR 41950 FEC 3/4
screenshots:
Pepeyeb
Toledo (España)
Buenas tardes
I get a good signal from the 12149V, 12188V and 12341V MIS transponders, in good weather.
Near Toledo capital
