- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
What is a 'MUPG' file type (as per first listed download) ?
Yes I had a password in my Receiver but I got to know that with this new Image the P/W has to be changed.Have you set a password, in your receiver?
Some of the latest images insist you set a password, before you can communicate, with your receiver, from your PC, including when using DreamboxEdit or Filezilla.
You can set a password using telnet commands, I used PuTTY to set a password.
Start PuTTY, enter your receivers IP address, select Telnet, and open.
Type root, and then press enter.
At the prompt type passwd and set a new password, press return key and confirm the password, you will not see the password, as it's being typed.
Re-start your receiver then try using your Enigma 2 PC software, remembering to use the password.
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10530 16-09-2020
Changes:
1. update os. to latest version.
2. modified bigger font size for subtitle.
3. modified SID numbers limit for bis.
4. improved SAT>IP function.
5. modified the subtitle position.
6. browser some minor bug fix.
7. some osd bugs fix.
8. Delete ALL channels freeze & hangup problem fixed.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10530 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10530 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10530 OK
SW offline - USB:
Recovery Bootmenu (E2):octagon_SF8008_v1.05.30_20200915
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
DUAL-OS_SF8008-SF8008m_v10530_200915
OCTAGON GERMANY SUPPORT
I had a go at updating the 8008 earlier with the attached files via USB stick, dcompressing to the usual kernel.bin/software.info etc.
I have ended up with a zipped up rootfs and user (.tar) files that the receiver does not work with during the firmware update. Are these to be further unzipped before puttng on the stick since there are a lot of files in there with exceedingly long prefixes, plus a lot of duplicate names that appear in the list.
Still not sure about the .mupg suffix either.
plug in a network cable, turn box off, hold front button, turn on. do an online update via internet
i dont understand your point.
flashing with the method i explained (which is outside of E2) - you have a choice of different images to choose from - Vix, OpenATV, all sorts.
u can also choose where you want them out of the 4 available slots.
Any assistance ?
The receiver will not update online (no network found despite there being a wired cable from the router.
I have had to reinstall ATV 6.3 for the time being, each time I try to update I get the same '240+' updates available, if I accpet and move up to the latest ATV6.4 (yesterdays) the receiver allows this and then hangs at 100 on the screen.
Yes, I'm using the same LAN cableas I do with the laptop and it is automatic.
this is my point, forget the USB method. although sounds like you might have a network port issue, does the network (wired) work when in E2 ?That was reported yesturday about updates and wont boot.
Try another ethernet port and get a ip address then you dont need to use usb. Just flash new image and start over or use a backup
Or if your in 6.3 or a working image, just press blue then flash online, select a image and then slot and its done.
Yes same happened to me....the RX will hang at 100. So I used the USB to install 6.4 from 6.3 (plus usb. update_bin. ) and it was ok thenAny assistance ?
