Advice Needed New recordable Freesat recommendation?
aceb
Prof Tuner 7301 /
Sussex
Mum's Humax HDR1100 has started to intermittently pixelate, I've checked the signal and compared results to an older model in the bedroom and it points to a faulty box.
I hadn't realised that Humax no longer produce Freesat STBs so that's annoying. Then I find the replacement Freesat branded boxes have hundreds of really poor reviews.
She's recently switched telco provider so can't take advantage of Sky Essentials so I'm looking for any recommendations for a suitable replacement that's easy to use and reliable.
aceb
Prof Tuner 7301 /
Sussex
Given the cost of a replacement 1100 or an equivalent (of which none have great reviews) I think I'll reinstate her old Foxsat-HDR which is still going strong and being used in the bedroom then replace that with a Freeview recorder. Her FV signal is OK for most of the time but it's a 100KM sea path so can get affected by tropo. That was only relegated to the boudoir because the iPlayer stuff stopped working but a new TV in the front room takes care of that.
I'd replace the caps in the PSU. They are notorious for failing and will likely fix the issue.
aceb
Prof Tuner 7301 /
Sussex
Thanks for the tip CJ, I'll retrieve it from garage and take the lid off to see what's required.
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
