Homebrew LNB
MarsBar
Technomate 3100, Universal LNB, 85cm dish, motor go to X
NORWAY, Karmøy
My previous setup had the LNB connectors up so the cables crossed the focal beam. Also not advisable considereing water ingress. So I swapped it today. Unfortunately its a tight fit for the connectors, cutting 5mm off the twist on connectors could be an idea. Or using a single lnb instead of a double that has connector higher up. Results are superb, 70% quality on BBC instead of 40% in heavy rain. Good improvement! Hopefully I have some weather reserve now for the winter. The LNB neck was cut and spliced using glue and some two component putty. Ended up as a messy job because I glued the bracket 90 deg wrong first...
So glue all over... used Tec7.
Looks a bit messy but dish is hidden behind the house anyhow. Think I will leave it for now. I would have loved to use a lathe to make a proper adapter though... I have also made a bracket to use a standard LNB, but using the original funnel I got outstanding results.
MarsBar
NORWAY, Karmøy
MarsBar
NORWAY, Karmøy
My location is Haugesund, 90cm dish. Heavy rain when testing. LNB is an old one I got for free.
There are 90 degree F connectors that may be of some use. Or turn the LNB 90 degrees, H & V will be reversed.
Just drill a pair of holes through the feedarm directly under the connections.
MarsBar
NORWAY, Karmøy
Yes indeed, angeled connectors exist! Will go hunting for them. Easy fix for the connector problem. Weather cleared up, 95% signal, 85% quality on BBC! That old dish, funnel and LNB is doing a great job together.
Matwrials used: Ink syringe with tape, centering the LNB in the pipe
Clear Tec7
Glass fibre two component filler (rapid stuff!) for holding the lnb into place
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Why do not you change the LNB for something like this (on the attached pictures)?
Availability ?
There are very few C120 flanged LNBs currently being manufactured.
RimaNTSS
N-E from Riga
Those, on my pictures are not flanged LNBs but usual universal ones adopted to Fibo feedhorn.
I know. I've kept back a pair of C120 Invacoms (single and quad) plus some Invertos that should satisfy roof requirements for a few years. No PLL versions though.
MarsBar
NORWAY, Karmøy
My budget is 0,- at the moment. As a temporary fix I cut off 5mm of the plugs, then took the sharp edge off using a sinker bit. (?) I had to use PVC tape strapping it on waiting for the transparent TEC7 to settle for a few days. I plan on making a transparent cover over the LNB later. Fair enough where nobody can see it.
I bet you spend 3x more in the pub each weekend than you would need to get new LNB :eek:
Slightly more than a drill bit of the right size.
RimaNTSS
N-E from Riga
I care if the hobby means there is a reduction in the refreshment.
RimaNTSS
N-E from Riga
Agree with that. There should always be some kind of compromise between hobby and "must be" . But, we always can reduce the amount of food in the fridge :D and clothes in the wife's wardrobe though.... even it can be dangerous some time :eek:
MarsBar
NORWAY, Karmøy
Beer is paid in cash and is filed under "michelaneous" in my montly budget. Anyway, fun to re use things like in Africa. Any in need of my old LNB? Works 100%.
Stop wearing them.
