Laminas 1200 owners - which LNB ?
Manikm909
Small'ish Dish Man
Kent, UK
hi all,
just wondering what LNB you might be using, and if you have it pushed forward or back in the holder
i was using a IBU until signals on 19e were low (maybe too overpowered needing attenuated) - replaced with a TM Gold and signal shot up, but i do wonder if there might be better options to pull in that extra 1 or 2 %
thanks all and merry christmas!
sonnetpete
wordpress.com
Normandy, France
IBU here, pushed as far back in the holder as possible. Haven't had any problems with 19E using this LNB...
Manikm909
Small'ish Dish Man
Kent, UK
thanks mate, yeah i posted a while back - I could get full arc at 98% at both ends 34.5w and 45e - but Pearl HD or Phoenix HD on19e was down in its 70%'s - when i knew that high 80%'s was achievable - replacing the IBU LNB got me that 89%
thinking about it, it doesnt really make sense, cos when i swung the dish around manually and peaked it JUST on that channel i could get the channels (mentioned above) at 89% - it just wasnt hitting it when using the motor to position it on 19e.
Trust
Nijmegen Netherlands
What type of Laminas do you have , the one with the plastic feedarm ?
Manikm909
Small'ish Dish Man
Kent, UK
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Manikm909
Small'ish Dish Man
Kent, UK
how would i measure that mate? i just put it together, and it worked...lol
RimaNTSS
N-E from Riga
I just put it together, and it worked...lol
Of course, it will work, but not necessary at its maximum performance. I do not know how to measure the position of the focal point, however it is calculable.
It is possible to check whether the LNB is properly placed: if we know antenna's offset angle and exact elevation of the received satellite then it is possible to measure the leaning of the face of the antenna. Then the measured offset angle should be exactly the same as stated by the producer. If they are different- the LNB's position is wrong.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Frankly, this test would just give a comparison between the stated offset angle by the manufacturer, and the actual offset angle where the LNB is located at the moment?
It doesn't say anything about the correctness of the stated offset angle, or about the focal length (which is related to the distance of the LNB to the dish).
Is that a step you saved for later...?
Or is this Laminas a non-flat-faced dish, where the calculation of the offset angle is a bit more difficult than at a 'normal' flat-faced offset dish?
Greetz,
A33
RimaNTSS
N-E from Riga
Of course, much better is to measure the dish and calculate all the parameters of it. And then an offset angle test can be made to find the exact position LNB should be placed.
Manikm909
Small'ish Dish Man
Kent, UK
hey guys....i was checking my signal strength (Laminas OFC-1200) against @william-1 list found here:
he's not that far from me, about 20 miles max, and he's using a 1m Gibby - judging by his profile....
i would have thought i would be equalling or bettering levels gotten by Williams 1m Gibby - do you think i'm not quite setup correctly, or views being obscured...?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
I get different db numbers from two different boxes on the same dish. Doesn't mean much really.
Manikm909
Small'ish Dish Man
Kent, UK
You see. I don't . 2 boxes fed by same dish and lnb . dB report is same on both. I can understand SQ and SNR being different
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Different LNBs will also give varying results on the receiver signal parameters.
Are you using a dedicated or feed designed by Laminas or just the clamp and LNBFs that are out there ?
Manikm909
Small'ish Dish Man
Kent, UK
i would say you have an issue there mate. thats not right.
are u able to swap cables over and compare readings...bet the values follow
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Done that. The Technomate always reads higher than the Zgemma.
Manikm909
Small'ish Dish Man
Kent, UK
interesting, as im unsing a ZGEMMA - wonder if my OCtagon SX88 will give me higher values
