Listen Up Batten down the hatches 2019/2020/2021
The wind has picked up today, outdoor work is no fun with the additional chill factor.
"Not going out" unless I REALLY have to!
But now, UNFORTUNATELY, I REALLY WILL have to go out tomorrow morning to get some flowers for SWMBO! :)
What special event is on the 13th of February ?
Something nasty on the way for Wednesday.
Amber warnings for the Jessies.
Must put more downforce on my car before I set out to York for my Covid jab tomorrow morning.
OTOH, put more "wing" on it and you could fly there :D
Since the wind has picked up I've noticed a distinct resonance from one of the masts installed upstairs, no doubt the neighbours will as well if I don't do something to dampen it. .
Well, Inam still getting signals from the dishes and tv aerial, but something large is rattling around on the roof.
Santa Claus with a faulty Sat Nav?
"March winds bring forth much firewood" :-doh
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Manikm909
Small'ish Dish Man
Kent, UK
its blown my dish out total alignment, cant receive anything even with USALS adjustment.
just when i had it perfect too.
edit: just went out to have a look - at 1w position it looks to be about 30e instead...lol - its been moved around on the pole.
Manikm909
Small'ish Dish Man
Kent, UK
the motor clamp teeth cant really bite into scaffold pole, like they can with softer metal poles, but then they bend...
Yup, that's why I had to really "beef up" the clamps for Darkmotor + Gibby on the scaffolding pole to stop the dish "sagging" by adding additional 3mm thick steel plates on top and below each one, with each pair bolted together very tightly - big pics of that setup from 2019 are somewhere on the forum!
Maybe I'll try to find that thread.
Manikm909
Small'ish Dish Man
Kent, UK
i remember that thread...
