Octagon sf8008/sf8008m mini multiboot with octagon sx88 linux os
Manikm909
Small'ish Dish Man
Kent, UK
You mean the newer SX88 4K can get lower SR's than the SF8008 ? not lower than 250k though ?
the sx88 4k cannot get as low SR as the NON 4K model - i have both - the sx88 CAN get 900 SR - the sx88 4k CAN'T.
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Can someone explain me if it is possible to use both dvb-s2x tuners on the octagon sf8008 whilst it is running the SX88 OS? Or how to configure it?I bought one for someone who wants to be able to record the french multistream channels and so it needs to have both tuners working together.
I think the Open ATV firmware is too complicated thats why it needs to be in SX88 mode.
Many thanks in advance!
No, only one tuner is permissable in the SF8008 with the SX88 firmware.
Stevenvc19
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Okay, thanks.
That brings me back to open ATV, I guess. Or is there an image that is more user friendly?
Okay, thanks.
No, these E2 images are more or less the same..
I found some 85+ updates for the SF8008 last night, though I'm sure I checked less than a fortnight ago. Perhaps one of those has improved things.
Since I posted the above I have found the receiver will accept perhaps six more batches of updates, al between 70 and 85. Whilst the receiver is performing satisfactorily I would like to add the Define image to compare.
The Octagon download site doesn't have (or at least I cannot find) a section for the 8008
Manikm909
Small'ish Dish Man
Kent, UK
First of all, make sure that you have a LAN cable plugged in (DHCP must be enabled on router) - now, turn on STB whilst holding the front button in....this will boot up into recovery mode, from here, you can flash any image into any slot, including the DEFINE image (which is similar software to SX88)
Ah, I thought I would have to introduce it with the Micro SD card, is there no way to do it without connecting the LAN cable ?
Manikm909
Small'ish Dish Man
Kent, UK
i havent tried other means, so i dont know im afraid - its VERY convenient using LAN, as it downloads the image directly without any faffing, you can choose from openvix, openatv, a few others, it then downloads and installs directly into the slot of your choice.
It's convenient if there is a wired connection within a few metres of the receiver, which is not the case here. I would have to pull the receiver into the office and find a monitor with HDMI input (or take the television off the wall)
Manikm909
Small'ish Dish Man
Kent, UK
Yeah of course it comes down to circumstance - you could always use a home plug to get a wired connection and re taking a TV off a wall - you could just buy a handheld field monitor with HDMI like a Neewer F100
The use of upgrade with micro SD (or USB of course) makes much more sense.
Manikm909
Small'ish Dish Man
Kent, UK
agree - hopefully someone else can assist
Manikm909
Small'ish Dish Man
Kent, UK
how about putting this onto USB stick:
extracting - booting into recovery as above - then choosing local install via USB into slot of your choice...not tried it, but in theory should work
ja5on
Vu+
england
I'd seen the word 'Define' a few weeks back, wasn't sure of attributes that I might prefer when running the 8008 here.
Can somebody provide a screenshot or two before I jump into the deepend ? Thanks
Manikm909
Small'ish Dish Man
Kent, UK
what do you want a screen shot of? the software look and feel , if so, same as SX88
video here...1m 50s
http://www.octagon-germany.eu/
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10541 11-03-2021
OCTAGON:
SF8008m Mini
SF8008 Single
SF8008 Combo
SF8008 Gold Combo
SF8008 Twin
Changes:
1. Fixed some channel A/V no sync.
2. Add. Reload function for Stalker in TV list.
3. Update Driver RTL88x2BU.
4. Hotkey fixed.
5. Add. smod.
6. Info Button Select the groups to hide in Stalker.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10541 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10541 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10541 OK
SW offline - USB .mupg:
Recovery Bootmenu MMC (E2) SF8008 & SF8008m:
OCTAGON GERMANY SUPPORT
