Manhattan actuator wiring
Stejc
DM800, Motorised Triax TD88, 45W to 39E. Digital+ HD subscription, TNTSAT HD Card.
Southport
I have bought a Manhattan 18 inch linear actuator second hand with no manual and I am looking to test it out with a short piece of 4 core cable to my Vbox, however I'm not sure of the wiring.
Can anyone help using the picture below as to which terminals on the left hand side should go be wired to the Motor Red/Black and Sensor Red/Black on the back of the Primesat PR1200?
I've looked online for a manual but haven't managed to find one and there is nothing on the back of the cap
Motor red
Motor black
Sensor red
Sensor black
Swap the motor wires around if the actuator moves in the wrong direction.
The motor drive are the two connections nearest the cable input.
Motor red
Motor black
Sensor red
Sensor black
Motor is red grey, (sensor purple/black) unless I've gone colourblind.
That is a very small actuator.
Stejc
Southport
Thanks guys. Once the baby goes to bed later I'll give it a go.
