Just Sharing This Nilesat 201 @ 7.0W - reception report
Satfaca
Melmac (46N, 14.5E)
DM920 + Octagon SF8008 + TBS 6925
Melmac
Just wanted to share this reception report, received in Ljubljana/SI with a 3.4m Prodelin antenna. I guess it cannot get any better than this. Here and there another one or two transponders get locable but ... this is pretty much it from this bird.
11747V.jpg11766H.jpg11785V.jpg11823V.jpg11843H.jpg11.863V.jpg11.900V.jpg11.977V.jpg12015V.jpg12.149H.jpg
MCelliotG
Thessaloniki, Greece
And how about Eutelsat 7WA on 7.3E, the beams are totally different.
Satfaca
Melmac (46N, 14.5E)
Melmac
Sure, those are two different satellites, 0.3° apart.
7WA gets here with 1 meter antenna, NWA beam with 2.4m upwards.
Butacas
90 cm motorised dish (1 m x 90 cm) + fixed [DiSEqC 3 x 1] {80 cm x 74 cm} Hot Bird 13° E, {65 cm} Astra 19,2° E & {60 cm} Hispasat 30° W + fixed {60 cm} Astra 28,2° E.
Motorised dish currently: 40,5° West to 45° East.
Vu+ Solo SE V2, Vu+ Zero 4K, TBS 5927.
Spain, Galicia (Ourense)
These are the frequencies that I capture in nilesat 201 {7.0º W}
Screenshots:
11746 V - 11765 H.png11785 V - 11823 V.png11843 H - 11862 V.png11900 V - 11938 V.png11958 H - 11977 V.png12016 V - 12034 H.png12054 V - 12092 V.png12149 H - 12207 V.png12226 H - 12303 H.png
Satfaca
Melmac (46N, 14.5E)
Melmac
Nice. But your location is some 2400 km away from me. :)
Butacas
I am missing some frequencies (Nilesat 201 7.0ºW) in which I have no signal. With a larger antenna it would possibly have a signal on all frequencies of Nilesat 201. :)
So the Nilesat 201 7.0ºW signal should not reach the north of Spain according to the coverage maps.
Extreme fringe reception is an odd thing - unexpected reception can happen. I used to get just one frequency off Eutelsat 25A in southern Scotland with decent signal strengths - no way I should have been able to get it.
You are getting the DVB-S transponders - the DVB-S2 stuff is missing. You would need much more signal to get them. Most other satellite providers have started moving over to DVB-S2 as it makes better use of the spectrum available, so if/when Nilesat start switching you will start losing frequencies.
MCelliotG
The exact opposite happens in Northern Greece. 201 is fairly easy with 1.20 (all frequencies come from 8 to 11db) but 7WA MENA is extremely hard, with some frequencies not possible even with 2.40!
Satfaca
Melmac (46N, 14.5E)
Melmac
Yep, that's why extreme fringe reception is such an "entertainment". Sometimes even 50 km distance means a huge difference.
stephan94
Bavaria
This morning I went pretty well with this satellite
I was able to get some difficult transponders ( for my place of reception north Bayern and 1,20 Antenne ); also with pictures.
10834V 4,8dB
10892H 6,0dB
10922V 6,0dB
11277V 5,8dB
11449H 5,5dB
11603H 6,0dB
Some TPs locked tonight on E7WA with my Triax 88. For example, 11.315V -
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Here I turn the antenna a little and play.
For the first time I caught this frequency in Slovenia with 7w.
Antena Gibertini 150
csb25
Triax td110, technomate 2600, inverto black ultra lnb, octagon sf8008 opevix 6.4.something, Nec E557Q. Dell optiplex micro 7040 with Linux mint.
Nottingham
It's raining cats and dogs for a change.
csb25
Nottingham
MCelliotG
Location, antenna size, receiver?
csb25
Nottingham
Triax td110, technomate 2600, inverto black ultra lnb, octagon sf8008 opevix 6.4.something in Nottingham.
MCelliotG
Thank you! I assume 33% is about 5db (and why not used, since SF8008 can display it).
This is much better than my location in Northern Greece where there is no signal at all on this diameter and even bigger.
rodscha
alkass 12245 ,kuwait 12523,bahrain 12226...seem to be on 26E,not 7w....
Tchad ,however ,is on 7W
marcouk
Vu+ Uno 4K SE, 1.2M Laminas motorised dish. Primesat 1.3 m dish
Hull UK
sorry posted on the wrong forum. :oops: was meant for the Badr 8 thread.
