Terryl
- Apr 14, 2011
- Age
- 82
Custom built PC
- Deep in the Boonies in the central Sierra Nevada mountains of California.
That LNB has a single output, with internal diseqc switching, you don't need an external diseqc switch for that one, go direct, then setup the correct diseqc switching in the satellites menu on your receiver.
And as others have mentioned, don't use that LNB with a motor, get a good universal single satellite LNB, and if needed then get one with dual or quad outputs for a second or more receiver's, but run the coax from the main receiver to the motor first, then to any (if used) diseqc switch, then to the LNB.
Receiver> Motor> LNB...
Or.....Main Receiver> Motor> Diseqc switch> LNB output #1.... then LNB outputs 2, or 3-4 to other receivers.
