Advice Needed is there anything after 53e receivable on 1.2m?
Manikm909
Small'ish Dish Man
Kent, UK
as per the subject... thanks.
I have no line of sight myself but I think 60E may be a possibility?
According to satbeams a 1.0m dish is indicated as OK.
You might get lucky with 54.9E on a good day, there were a couple of strong frequencies on the Northern beam last time I checked.
I was way above the level required for a lock with a 2.0m dish so a 1.2m might just about be OK?
I can on my 1.2 CM, anything in particular you might be interested in and i will take a look for you.
Where is your location roughly
Manikm909
Small'ish Dish Man
Kent, UK
hi mate - thanks - not really - just wondered - was gonna drive dish and blind scan - however, without a known TP or channel, i wont be able to drive my dish to know if i can get or not...im in se london \ kent
Actually, I forgot, 68.5E is OK for a 1.2m dish in the UK but it is low in the sky and not easy to get line of sight.
If you enter any currently active frequencies from the Northern beam of 54.9E it might get you a hit.
It is only 1.9 degrees further East than 53E so should be about 22 clicks on the v-box if you get 11 to 12 clicks per degree.
I get this transponder on 53E 12594 V 27500 on a 88cm dish,
Restricted view so this is as far as my arc goes East.
12522V 27500 on 54.9E is strong enough to receive on a 90CM here in the north east, I seem to remember the Northern beam being a little stronger in the south of the country too.
Gladstones
Zone 2 Fixed @ Astra 2
Technomate TM2600
Inverto Ultra Black
LG 55 UH770V
Octagon SX88+SE
Midlothian
12522V27500 @ 54.9E in Midlothian
stephan94
Bavaria
Hello ,
the 62 ° East and the 66 ° East are also receivable with a 1.20m, but I am not in the United Kingdom
but in the north of Bavaria
Manikm909
Small'ish Dish Man
Kent, UK
thanks everyone...
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
I'm able to receive 62e with a CM 1.2m at 12.5db in Essex.
Manikm909
Small'ish Dish Man
Kent, UK
Thanks mate. Can u give me TP details ple
Chr0nik
Grays, Essex
11555 V 30000 3/4
All of them are Iranian channels.
I've managed to get this one but I'm unable to get anything past 15w so must be receiving this one by pure luck.
Manikm909
Small'ish Dish Man
Kent, UK
thanks mate? did you actually mean 15w? u cant get 15 or 30w?
nelson_b
Contributor
11555 V 30000 3/4
Hi
Also here at 62 E in North West U.K. - With Channel Master 1.2
Chr0nik
Grays, Essex
yes, can't get the antenna to get the arc properly. if I want to keep the most eastern days, I lose 15w and the most western ones.
Manikm909
Small'ish Dish Man
Kent, UK
are you using polar mount \ actuator ? is your pole dead straight.
i recently swapped and moved my dish, swapped my old 2inch pole for a 3 inch pole and have ditched USALS \ Diseq motor - to an H-H 36v motor, i paid special attention to pole when installing my CM - making sure it was dead level, the result, my arc has never been so good, around 16-17db on 30w and 45e - even on old setup with USALS, i never got that...even 53e at 14db atm.
that DB reading is from an Octagon SF8008 - i actually think they "under read" the value - as when i briefly had a TM5402 M3 - the readings were usually 1db higher on the TM, than the Octagon. Not sure which STB is to be believed, lower or higher reading.
DonSE2
TD110
London
11555 V 30000 3/4
Is anyone pulling in 68.5e and can provide some signal readings to me?
I've relocated my Triax 1.1 to my roof but there is a tree which I think is partially blocking the signal. On 62E 11555 v 30000 signal seems to fluctuate between 10.5-12db, which seems pretty good but wondering if the fluctuation is caused by the tree swaying in the wind.
On 68.5e I can actually lock some transponders 12722 H 30000 for example even though signal reads only 2.8db and the picture comes and goes. I could shift the bracket up 10cm to give me some more clearance but I still don't know if it would be enough.
