NSS 806 at 47.5°W
If anyone is around in the next couple of hours would they please be able to have a look at this feed to see if they can get a lock and see what it is?
47.5W
3765 R, SR 7500, Possibly with FEC of 3/4 and 8PSK modulation.
I have 6.2 dB and if it is with the parameters listed above it needs around 7.9 dB for a lock. I have attached a picture below of my EBS Pro signal analyser result.
47.5W
It's ID is MX1 - ENC-9, but topping out at 7dB max here up North - - bare with
A bit more info on it but i can't get it to clear for me - BISS encoded. - it's a good solid lock from 6.5dB upwards for me MB
MB - will it be Trinidad v St Luc if so , think iv'e found it on 55.5°W but can't open it at the moment
Here's the info just in case ....
@John
Many thanks for the details, most appreciated.
Unfortunately I have no chance for 55.5W at the moment, leaves on trees and no good location for the mobile dish to get a glimpse through to the satellite. It looks like you are a few tenths of a dB above a lock with your 2.2m which probably means I would be struggling with a 2.0m?
.. 47° West -Large chemical plant fire - Rouen. - Feed
47.5° West
4.158 LHC 7199. 5/6. 8PSK. DVB-S2 Fta. Table tennis finals.
African Footy??
ATP Swiss Open....BISS
GT Media X8 MB. But the TM is also pouring the Poop...
The TM-5402 (M4) seems to be developing into a tasty little box, it has been excellent work by forum member "manic01" in pushing Technomate to provide updates for it.
dcdi36
Triax Dish
Croatia
Hey guys. How big a dish is needed for this sat in Europe? I only have CM 1.2 metre dish.
It requires a bit more than just dish diameter unfortunately.
Two footy matches, one ladies one gents..BISS20210729_185219.jpg20210729_185238.jpg
