NSS 806 at 47.5°W
gydstj
1.2m dish
Japan
.. Not sure if this one has been mentioned recently,
47.5 West --- 4095 RHC. 9875. 3/4. 8PSK. Encrypted. Provider: EBUER. ID: Fi16 CHEVC.
Can anybody make anything out of it ?.View attachment 93863
Excuse me, brother. you can receive EBU feeds ?
47.5 West.
3869 L. 7200. 2/3, DVB-S2, 8PSK. - ID: Telecity ENC 4.
Derby v Birmingham.
47.5 West.
Swimming -
3829 L. 7200. 3/4. DVB-S2. 8PSK. ID: IKO.ISL NAPLES to SES 14PRI.
French Feed for 911.. FTA
47.5 West.
3740 R. 2343. 5/6. DVB-S2. 8PSK . FTA. ID: DTV1
Not sure if this is a new feed or a new program pro-mo. Some weird Chinese or Japanese sexy time type of thing.
Manikm909
Small'ish Dish Man
Kent, UK
what extra equipment do you need for CBAND - can you do both Cband and KU band on same system? or do u need 2 setups - one for KU and one for C ?
Options:
1. Attach a C-Band LNB alongside a Ku-Band LNB on the same dish.
2. Fit a "Trust Multi Band LNB Rotator" to the dish (offset dishes)
3. Separate dish for C-Band.
Basically, you need a C-Band LNB on a dish of sufficient size to receive the signals.
For the receiver, all you do is edit the LNB configuration to C-Band, generally with L.O. of 5150 MHz.
Any auld junk receiver should do the job provided it has the option to set the LNB L.O.
For upper C-Band frequencies beyond 4200MHz you need an LNB that can cope with that range, generally these have a higher L.O.
To get decent reception at a UK location from a range of satellites I would think a 1.8m dish is your starting point.
You can get C-Band on smaller dishes but you will be missing a lot of frequencies.
47.5 West. FIFA Test card. BISS
3895 R. 9873. 3/4. DVB-S2 8PSK.
47.5 West.
Down tiger...
47.5West
Football feed.
3875 L. 7200. 2/3. DVB-S2 8PSK. ID: Telecity Enc 2.
and
3878 L. 7200. 2/3. DVB-S2 8PSK. ID: Telecity Enc 5.
47.5West
3888 R. 7200. 3/4. DVB-S2 8PSK. ID: Fi10_GNVE. BISS2 i think ?.
London concert ?.
47.5West
London concert ?.
Might be that Ed Sheeran thing from Paris..
47.5 West.
Awards Feed. FTA
4147 L.
Also - 47.5 West.
3808 L. 7200. 3/4. DVB-S2 8PSK. - BISS Feed - Football - Dutch Lg VIT vs FEY PRI. - - Couldn't grab the screen shot before the feed dropped.
