rather cool satellite meter
i have used the v8 sat meter going fishing with a small plastic 35cm dish antenna.
Plus you re-charge with a 12v solar panel dc car battery charger when off grid.
The battery last for 2hours for tv viewing.
Yes, it does work quite well as a monitor/satellite receiver.
I keep one in the portable/caravan suitcase unit instead of the 'Ross' HD receiver that came as standard (which could have been a superb system if only the bugs had been ironed out).
The built in screen (and both connector outputs) show the battery level indicator in the top right.
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Yes i used the lidl camping dish one as its plastic and lighter.
goatman
dreambox 500s, dg834gt router
hard wired router/dreambox
notts uk
any one got any info on how to use this to setup a motorised dish ?
i used it to tweak the dish in early spring but dish has moved slightly and i can't remember how i did it last time
does this meter drive the motorised dish ? just going to check extreme sat's and their outer frequencies
Manikm909
Small'ish Dish Man
Kent, UK
Yes it can steer the dish as it has usals built in . I did it on mine but now I'm 36v
goatman
notts uk
how do i get it to steer dish, just can't see how
simple guide would help so much
Manikm909
Small'ish Dish Man
Kent, UK
sorry mate, cant remember, it wasnt difficult from memory
Post some photos of the menus, it shouldn't be too difficult to work out :)
goatman
notts uk
think i've sorted it but need to try it
To move dish
MENU
ANTENNA CONNECT motor
SATELLITE LIST 0.8w 13e 19e (ones I mostly use)
SETUP (yellow button)
MOTOR TYPE usals
MOTOR SETTINGS
SELECT SATELLITE (top box) dish should move to satellite
Manikm909
Small'ish Dish Man
Kent, UK
did it work in the end, moving the dish i mean
@manikm909 did you ever try 10493H 1500 on 26°E? :)
Manikm909
Small'ish Dish Man
Kent, UK
can you remind me what i was going to do? :confused
On the meter try to tune 10493H 1500 on 26°E where there's a promo video. Some of these meters can tune below the usual frequency range, which enables them to view the amateur broadcasts on Es'hail 2.
