Just Sharing This Worked out why I cant get beyond 53e !!!
Manikm909
Small'ish Dish Man
Kent, UK
today i went up ladder to adjust motor limits on East side, thinking this was the issue, anyway i wasnt up the ladder for long when i noticed the actual cause!
the dish mount is hitting the motor mount casing!!!! DOH!!!
oh well, dont think theres much after 53e to worry about
attached pic of issue
That is going to be awkward to fix.
Have you considered inverting the reflector ?
Manikm909
Small'ish Dish Man
Kent, UK
thanks CH - i wont be doing any fixing, i'm happy to leave as is, until it packs up, then i will probably fit my polar mount and actuator (new - gathering dust)
Good luck breaking it. I have three customers with the same motor, probably coming up to 20 years old now.
Manikm909
Small'ish Dish Man
Kent, UK
Manikm909
Small'ish Dish Man
Kent, UK
ive just noticed i should really do that alignment bolt up, as winds could tilt dish \ mount back, but they'd have to be heavy winds.
its a funny old CM mount - looks home made to me
No, that was a universal bracket that was part of the motor system.
Terryl
Custom built PC
Having never seen that type of motor mount before, could the motor (or mount) be turned so it's 180 degrees at the back of the dish, instead of 90 degrees off to one side??
Manikm909
Small'ish Dish Man
Kent, UK
its a Jaegar smr-128g - nothing you can do i dont think...this post has some nice pics of it...
You could extend the backplate to motor mounting points.
Manikm909
Small'ish Dish Man
Kent, UK
i think by doing that, it would introduce flex, and weaken it, its fine as it is. 53e to 30w plus, is fine by me
its a shame the motor casing isnt on the west side tho, as theres more to the east than there is to the west i guess -but probably not much on KU band
Might be worth taking the motor cover off just to see if you can receive anything further east. Does removing the dish bolt allow it to get any further round?
Invert the dish
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Invert the dish
With the existing backplate? Correcting twice the offset angle of the dish to its declination angle (which is now [dish offset angle PLUS declination offset angle], to [declination offset angle MINUS dish offset angle] ),
it doesn't look like the motor construction would allow that.
As the motor would likely not collide with a PFdish backplate, I would be thinking more of the option of two backplates: One at PF-dish angle, with the motor attached to it, and another one for the offset angle.
But it is nice to theorize, as it looks like manikm is not going to do anything about it.
Greetz,
A33
If the dish could be mounted a few inches higher with an extra plate between the dish and original backplate, the offending corner could then be cut off.
zorrin
Specialised contributor
France
www.facebook.com
france
I have the same motor in the DiSEqC 1.2 version but with a different attachment on the antenna side
I can send you more information on this different part tonight If that can help you.
Manikm909
Small'ish Dish Man
Kent, UK
that stem is like the one on the SMR-99G
thank you for the offer. i wont be trying to fix the issue - happy with the range i have.
Manikm909
Small'ish Dish Man
Kent, UK
i might try removing the bolt now, if i can get 52e at 21db - i think im very close to 55e - could the dish survive with 3 bolts?
Should be fine in all but the strongest winds. When they arrive just move the dish back round and put the bolt back in.
